More figure in Hollow Trees.
Keith Newton----Little Rock, Arkansas
Over the past weekend, while out in the woods hunting, I came across the remains of a hollow Beech tree. This is just the last 1.5" thickness of only half of the circumference of an old snag that was left after the rest had rotted away. It finally collapsed, from lack of support from the inner trunk.
In the past, I have harvest other hollow trees, that had wonderful figure as well. I suppose that once the support of the core of the trunk is missing, that the hollow shell is not only under more compression from the weight of the limbs and canopy, but that the remaining cambium and sapwood layer are subjected to more dynamic loads like twisting and bending than normal wood, which may induce the cells to start developing more figure that would be more resistant to splitting or torsional loads.
I was just wondering if there are others here that may have noticed this, and have taken advantage of it, or do you just see the hollow, and walk away.
I hope the timber company which owns the land will let me get this wood. It has a heart shaped window from an old scar, with loads of other character.
I just thought I would post this as a suggestion for those of you who harvest your own wood, to take a closer look when you see especially large hollows. You may need to knock the bark off to see what is hiding under it.
Don't just assume that because most of the wood has rotted away, that all of the rest is worthless and rotten.
I am not suggesting that you will be able to get nice flat planks out of what is left, but you may be able to get some incredibly figured wood, not with just a natural edge, but a natural face. Usually free for the taking, and not that hard to render into a usable format, certainly good for small turnings like platters, lids, maybe boxes etc.
