Howdy I have a few Christmas gifts to make and a sale or two for some French Rolling Pins. Now my simple question is: I have seen pictures of these and they look like a straight spindel. Am I missing something? What is the normal size of these things? Also I was planning on finishig with mineral oil or should I just leave them unfinished.
I like to use a product called "Preserve" on the rolling pins I make. Most of the on line outlets have it I've found it at Hut Products and Rockler. Eagle America also carried it and their outlet store is nearby so I get it there. It's basically nut meat oil but it "dries" and doesn't always appear to stay wet like mineral oil does. I apply a liberal coat and allow it to stand overnight and wipe off any excess oil that might remain. It's a great product.
I made my wife a maple rolling pin. She said she didn't want handles so she got a cylinder very slightly under 2" in dia and almost 12" long. She thinks it is great and uses it all the time - she has other wooden ones and a marble one.
She has said she would like one a little smaller in diameter and I get the impression that it is the type of item being made and personal preference that dictates the size. Nothing it simple!
The French model is slightly tapered but I don't have one to tell you how much it is tapered. I read the idea is that it will make a pie crust thinner in the middle but leave the ends thicker.
I put mineral oil on it when it was made and it hasn't been redone since. Probably picks up "oil" from the batter as it is being used.
I'm going to make my mother a dumpling cutter. I haven't decided on a size yet but probably in the 2 to 2 1/2" range. I am planning on finishing it with Mahoney's walnut oil.
I have made 3 of them and they have been 10", 12", and 14" long. I made them 2" in diameter tapering down to about 1 3/4" at the ends. I finished them with Mahoney's walnut oil. As far as I know nothing has been done to them since or at least I know my sister has not did anything to hers since I made them.
If you Google French rolling pins you will find a lot of pictures. I make mine any where from 1 1/2 to two inches in diameter. I try to make the contact surface about 12 inches long and then 3 inches of taper on each end; tapering down to about 1 inch. Have fun. Jerry
There are a number of variations, and none seem to be the one that every one wants.
Style 1, straight center, and taper the last 3 inches or so a bit.
Style 2, straight taper from the center out to the ends.
Style 3, gentle arc through the whole length of the rolling pin.
There are straight cylinders as well, some with handles, some not, but I don't think of them as the 'French' style.
Lengths can vary as well from 14 to 16 inches, down to 9 inches or so for a Palote (tortilla rolling pin, which I always made straight, but ran into some one who wanted a tapered one). Diameter is seldom over 2 inches.
I finish with Mahoney's Walnut oil.
I only use Sugar/hard maple. Cherry and apple are nice, but do not have the weight. Beech is great as well, but is almost impossible to find out here.
I've made & sold a couple dozen, all finished with tung oil. I like to make handles of a different species and color (turn a dowel on each end of the pin blank to fit a hole drilled into the handle, or do it the other way around). The ones that sell the best are larger in diameter (about 3") as they seem to be easier to operate, especially by older ladies with arthritis.
I turned my first rolling pins about a month ago and have sold 15 since then. The size is a matter of personal preference. As was stated vary them in size and wood species. "de gustibus non dispudundem"
I have made them from maple, cherry, osage orange, elm, walnut, hickory , locust, peach, apple, plum, aromatic cedar and even golden rain tree. Pretty woods catch the eye and sell bettter. If you google hand turned rolling pins you'll find all kinds of sizes and variations.
Now I have a few ideas of what to do. I will contact the ladies that asked me to make them and make sure what size will work best for them. Thanks Again
I'm sending one out on Fri. I have made all sorts, but the one my wife likes best, and what I now make pretty exclusively is about 20" long, 2" diameter in the body with tapers 4" from the ends down to 1". I also prefer sugar maple (curly) and use mineral oil.
If by 'golden rain tree' you mean golden chain, what the Brits call Laburnum (Latin name), that wood, tree, flowers, bark, and every thing that goes with it is very toxic. I don't use the hickory or walnut unless I can fill the pores, and that is too much work for me.
no Golden rain tree. It is an oriental import from China and Korea, used mostly as an ornamental. It does not get too large, about 20' high. Botanical name Keolreuteria paniculata. It is a prolific seeder and can be a nuisance.
