Veritas - Innovation in Tools
drying wood in a old refrigerator
Jim Canning
I am going to try drying out wet roughed out bowls in a old refrigerator. I pick it up tomorrow so what I am wondering is what is the best way to set it up(holes,lights,fans etc.)?
Thanks in advance
Re: drying wood in a old refrigerator
Steve Kubien
Steve Kubien
Hey Jim,
I did the same thing a little while ago and I love it. Mine is very crude. I have a clamp-on light fixture in the bottom, a half dozen holes drilled through the side (1/2" I think) and a 4" or 5" desk fan blowing towards those holes. That's it. Oh, I keep a unit inside to tell me temperature and relative humidity.
My system is simple and seems to work...
For approx two weeks, I have a 40 watt bulb in the fixture. I weigh the pieces every couple of days so I have a clue where they are at. Probably don't need to.
Next, for another week or two I have a single 60 or 75 watt bulb in the fixture. Same regime with the weighing.
For the final week or so I have a 100 watt bulb. When they stop losing weight, I know they are done.
Interestingly, I will weigh them when they come out and they will sit around the shop for a week or two (or longer if I get distracted by something shiny). I often notice and INCREASE in weight by the time I get them back on the lathe. We're only talking a percentage point or two. What this tells me is the my kiln is doing its job. I might be able to speed things up with an extra fixture and more air movement but we are talking 8 weeks max. from rough to ready to finish turn so I'm not bothered. Oh, and I obviously don't have a vat of highly flammable DNA sitting around any longer. I like that fact.
Rob Wallace
Re: drying wood in a old refrigerator  *LINK*
Rob Wallace
Check out the link below for a recent discussion on drying kilns made from converted refrigerators/freezers...
Rob Wallace
Recent Thread on Drying Kilns from AAW Forum
I have dried chair spindles and legs in an old refrigerator with just a shielded light bulb and top and bottom vents. It worked well for me - until someone wanted me to get rid of the refrigerator.
Matt Overton
thanks, Rob. I have just converted a commercial freezer into a kiln. This is very helpful. I wasn't going to put a fan in it, but now am thinking I should. What do you recomend?
Matt
Joe Herrmann
Ted Rudie did an article for Woodturning Design magazine about making a kiln in Issue #24, Winter, 2010
Rob Wallace
Using a kiln air-circulating fan.....Yes!
Rob Wallace
Hello Mat!
I would suggest installing a small fan (the one I used for my kiln prototype was a 110 volt "muffin" fan pulled from a discarded computer. It certainly would not hurt to have air circulation in the kiln to assure uniform slow drying. You can rely on thermal convection alone, as many do, but results will be more uniform with forced air circulation (...but not forced air exhaust!)
The idea of using a kiln is to have controlled drying which allows stresses in the wood to be relieved slowly and uniformly as it dries. Even if the air in the kiln is very humid, there is something to be gained by having both air humidity and temperature evenly distributed throughout the kiln. The next version of my kiln will have the fan switchable externally, as well as having digital temperature control (using a discarded but working PID controller), as well as having a separate digital thermometer and hygrometer (a combined unit purchased inexpensively on eBay - search on: Digital Thermometer Humidity Meter Hygrometer Air HY303). I intend to do some wood drying experiments, and need the monitoring capabilities without having to open the door to get the data; most folks won't need these features, but they will be nice to have in place!
If you have access to a fan, I would try it! Recycle one from a computer, and if necessary use a suitably-sized "wall wart" transformer/power supply to power it if the fan's voltage is 12 V DC. You can typically find these in the power supply unit of a desktop/tower PC.
Good Luck!
Rob
Re: Using a kiln air-circulating fan.....Yes!
Matt Overton
thanks Rob
