LinkBelt and Lathe?
Thomas Norton
On an earlier post I ask about the correct height to remount my lathe. Thanks to all who responded!
When I do re-position my lathe I was wondering if a LinkBelt would work?
LinkBelt and Lathe?
Thomas Norton
Re: LinkBelt and Lathe?
I've had good success with them on two different lathes. One even had a reeves drive which they aren't supposed to be good on. Be aware there are two sizes. I forget what they are now but you do need to buy the correct size or they won't fit down in the pulley correctly
robo hippy
My first lathe was a 4 speed/pulley Atlas. I built a bigger heavier stand for it, and used a link belt. Perfect for the job. I did not have to take the headstock apart to replace the belt, I could leave a little slack in it which made it really easy to change speeds, and it lost no torque. Also, after the belt stretched out a bit, it was simple to remove a link or two (easiest to do with needle nose pliers) to tension the belt back up proper.
robo hippy
LinkBelt and Lathe? Why sure...
Scott Burr in Ben Lomond CA
Just make sure you have the belts going in the right direction and remember they will stretch a bit after a few uses. Also if your lathe runs in reverse the belt can do it but it's a bit noisy and not as smooth running.
Janet Bequeaith
Yes, there are two sizes, 3/8 and 1/2. I have a General table saw and it takes the 3/8 one. I'll have to check my lathe size.
5/8 Too
Bill Howatt
