Lathe Height?
Thomas Norton
I would like to get back into turning for some upcoming projects. What is a good height to have the lathe in relation to a persons's height?
Thanks
Lathe Height?
Thomas Norton
Thanks
Re: Lathe Height?
Dave Belser
Spindle height close to inline with your elbows works for most people!
Re: Lathe Height?
Rob Wallace
Thomas:
The general rule of thumb is to hang your arms straight down at your sides, bend your forearms frontward (forming a right angle with the upper arm) and then measure the height from the floor (or working surface) to the bottom of your elbow. The lathe spindle height (center axis) should be within an inch above or below this measurement.
If you intend to do a lot of freehand hollowing, some prefer to have the lathe a bit higher.
Cheers,
Rob Wallace
Re: Lathe Height?
Joe Fleming
An orthopedic surgeon and woodturner told me that for bowl turning and other facework including hollow vessels, the spindle set at around 3-4" above elbow height is better for your back. As with all things, there are compromises. I do a fair amount of spindle work and find that the 4" height works OK for me. I've been doing this comfortably for about 10 years.
Joe Fleming - San Diego
I actually have mine lower
steven antonucci
I do a lot of freehand hollowing, and I have mine lower because I can still keep my weight over the bar. Truth be told, I think it matters more how you cut than what height the centerline is.
My handle is always low, edges on or above center...
S
Re: Lathe Height?
It kind of depends on what you turn and your posture as well as how you hold the tools. I like mine about an inch above elbow height. It seems to cause less back pain and since I turn with the handle on my body this height lets me put the handle on my hip.
Re: Lathe Height?
Peter Charles Fagg (UK)
Mine is the same, my back problems were solved by having the lathe at 4 inches above elbow height.
Better to try different settings than persevere with a setting that causes other problems, everyone spends much longer than intended at their lathes!
Regards, Peter.
