microwave drying
microwave drying
karl jr
microwave drying
karl jr
I nuked a bowl as a test. Three 15 second cycles at a power setting of 3 (out of ten). I didn't weigh it during the process or use a moisture meter, but it was surprising how hot the bowl got in such a short amount of time. After a few swipes with a card scraper and some Watco danish oil the bowl was looking pretty good. I might do that to the rest of them.
Is it worth it to nuke a bowl a bit, to dry the surface enough to sand and apply finish?
KTK
Re: microwave drying
Keith Inscho
I have tried this a few times and it does work if you are in a hurry. You still have to go through lots of warming/cooling cycles to get it dry enough to put a finish on. Too much moisture left in the wood will cause problems with most finishes I think. I have also tried alcohol, and that works as well, but also has its share of problems. Its easier for me just to rough turn and let time do its job.
It works, but.....
Ray - Middletown, IN
use a scale and keep an accurate record of the weight loss. One minute on and 5 off worked for me, however, when the weight does not drop anymore,,,,stop. Don't do the one extra cycle to be sure. Copious amounts of smoke will flow from the microwave and the bowl will glow quite brightly.
Also don't do this when your wife is standing by to offer criti... uh,, helpful comments about the process.
DAMHIKT
Ray
karl jr
karl jr
Keith,
thanks for the reply. I'm definetly in a hurry. Anything that can speed the process up is what I want to hear about. I've got a handle on procurement and processing, but I really haven't dealt with the phinishing phase yet ;)
Meanwhile, I've got a stack of bowls drying that need some finish work before they go out the door.
I've got nearly twenty days until my (extended) delivery date.
KTK
karl jr
It might work, but
karl jr
it might get other people in a snit. Particulary when the microwave no longer pops popcorn! :)
KTK
Old microwave in my shop
Jerry Hall
I put them in a plastic bag, get them hot to the touch and leave them sit for a while till just warm, then turn the bag inside out (dripping wet) and do it again. After a few cycles of this I may use the microwave several days as a kiln, with the light on and the door almost closed. I have an old microwave in my shop. Wouldn't do with out it for drying stuff and warming up my coffee. Anyway I can take several bowls to pretty dry within a week. I think steaming in a plastic bag cuts down on any cracking, sort of like a boiling regimen, but can't prove it.
Karl You didn't say how thick your bowls are. I have microwaved a lot of things but usually smaller stuff. I have done a few bowls to see how it works but it's not worth the effort for me. I dry the surface with a hair dryer. That lets me sand them. My bowls are usually 3/8" thick or so and they dry quite nicely in 2 days in the shop. Then I can do a final sanding if necessary and apply finish.
I experimented for a while with drying rough turned bowls. It works but takes too many cycles. If I was doing more than one or two I would go nuts. I would rather rough them and put them on the shelf and let nature take it's course. I can be turning something else while they dry or simply be roughing out new ones or turning the dry ones I have stored.
Alcohol or dedicated drying cabinets seem to be the way to go if your into production and in a hurry. I haven't experimented with either yet.
Dick Hines
Dick Hines
I soak my bowls and other things in alcohol. Depending on how big the pieces are they will be stable after 30 days of so.
matt overton
Dick, how long do you soak them? Do you just air dry, or drying cabinet for the 30 days. I assume it is just denatured alcohol.
karl jr
karl jr
John, I'm turning these bowls to about a quarter inch, plus/minus. In the past I let them air dry, like you and others mentioned. I thought perhaps I could save some time by nuking them. However, I didn't really think that one through. I'd be standing at the microwave for days trying to dry thirty-some odd bowls. I guess I'll try a hair dryer, as you suggest. Or just be patient.
Thanks,
KTK
bill Crommett
If you want to use an old microwave for a drying kiln just cover up most of the vent holes and the microwave will then act like a commercial kiln and let the moisture out slowly so the work piece wont crack. Power and time will vary for the individual oven. Sorry, Karl, this will not be of much help to you in your rush.
karl jr
karl jr
I'll have to keep that in mind until a get a chance to do some research.
thanks
KTK
