It is not really Off Topic, I made a Longworth chuck and works well, but I am trying to make it work better.
I did use half a wine bottle cork in each of the 6 bolts, but I would like something a lot taller and with a pronounced taper, like in the test tube stoppers, the ones with a hole for tubing would be just right.
Do you know of a chemistry supply house that would sale retail? My searches did not find any.
I haven't had a chance to build mine yet, bench space/cleaning issues I did pick up a couple of packages of the white cane tips that they sell at Home Depot. They seem to have a pretty decent taper to them and they are inexpensive.
Jorge: You can also try Carolina Biological Supply (link below) who sells on-line and they take credit cards directly.
Rubber stoppers selling for about $ 11.75 per pound, any size; I recommend getting the one-holed stoppers unless you have a means to make clean holes (Twist drills don't work too well - when needing to make holes of different sizes, I used to freeze the stoppers overnight at -80^C and drill them with a brad point bit or Forstner bit on a drill press while frozen, and it worked pretty well). Lab stoppers are all about 1 inch tall, except for the really small sizes.
I made my first longworth 4 years ago. I tried the tip covers for canes and chair legs and found them not to have very good holding ability. The rubber stoppers have worked well for me. I put a washer on top of the stoppers to make the pins more rigid. The rubber stoppers are available at many hardware stores that have those specialty bins with wide ranges of sizes of cap screws, cotter pins, bushings, specialty nuts, etc. They often have layers of these sliding cabinet bins. I know it is hard, but ask for help.
Look through this site and you will find tons of oddball stuff you can't find anywhere else. I have ordered from them several times and have always gotten A++ service.
Your local hardware or plumbing supply store will have test plugs, (very) mildly tapered rubber stoppers with a bolt through, designed to plug up DWV (drain-waste-vent) plumbing while pressure testing it. These come in various sizes for the various common DWV pipe sizes. They might be pricier than the plugs Keith suggests from McMaster-Carr, but you won't pay shipping* and you can hold them in your hand to decide if they'll work. They're also of a slightly softer composition, designed to compress/expand; and, on most, you get washers and things sized to the plug that you could use for mounting them.
Buy a Set from one of the companies that makes Cole Jaws. They will sell you spares. They have already done the "Engineering" or product selection.
If you buy something else and convert it to this use, you might want to see if whatever black rubber you buy leaves a mark. I tried some that did leave a mark and it was tough to remove if the piece slipped a little in the jaws.
My favorite grippers are "L" shaped pieces I made to expand the capacity of my Cole jaws. Mine are about four inches long, but they don't have to be. You bend six or eight pieces of strap steel past ninety degrees and drill a hole in the longer leg for the bolts and dip them in the rubber they sell for dipping tool handles. They hold much better than the rubber bumpers.
Surprised to see all kind of places to get the plugs, from Carolina Biological Supply a logical place, to McMaster-Carr, a place I would never think carrying these, as I have gotten metal and tools from them.
At the meeting in our club, a fellow suggested wrapping the plugs in masking tape to prevent marks.
They're easy to make from any convenient hardwood. If you want to get fancy, you can slip a short section of vinyl tubing over them. For tapered buttons, electricians heat shrink tubing will conform to the shape.
I use 1/4-20 bolts with wing nuts to mount the buttons. Be sure the hex head of the bolt is captured in the button.
I find that a polyethylene washer placed under each button makes them move easier. The washers can be turned from pieces cut from a milk jug.
An easy way to get a clean cut on a short section of vinyl tubing is to slip it over a mandrel and use the long point of a skew (paint can opener).
