Re: Sound Control
rjstavran
I do believe there are a couple of things to keep in mind. A previous reply mentioned sealing doors, windows, switch plates, etc. Think of sound as you would cold air entering your home - insulate. The other thing is to avoid sound transmission by contact. A second layer of sheetrock nailed over the first does very little to limit sound transmission. Your idea of a foam board between layers would be better at controlling sound.
It sounds like the wall is already there, but if you were to construct a wall, make it with 2 by 6 lumber for the bottom and top plates. Use 2 by 4 lumber for the walls but stagger them with every other stud flush with the inside or outside of the wall. The inner and outer wall surfaces only touch on the 2 by 6 lumber. I would also use fiberglass insulation in the wall cavity.
Another avenue is to make the wall soft. Covering it with carpet, heavy curtains, soft foam pads, empty egg cartons, blankets, etc. That would make it difficult to use the wall for hanging storage. and could be quite the dust magnate/collector.
