A55 Smoothing Plane
Kelton Hollowing Rig Clearance
Bill Howatt
How much distance is required from the middle of the bed to a wall located behind my General 260 for the standard size Kelton Hollowing rig's piece that is mounted perpendicular to the bed? I have about 18".
Thanks,
Bill
Re: Kelton Hollowing Rig Clearance
DARN!~  I Thought there was a sale
George Guadiane
Terry Scott
Bill I stand around the back of my lathe when using the rig so 18inches wont even fit my gut
Seriously I find having the lathe clear all the way around means I have more freedom to get the tools on angles that I couldn't normally do if against a wall
I think your 18 inches maybe a bit tight for the long rails sorry to be the convener of bad news
glenn roberts
Terry is correct. having plenty of space around the bed is something we don't think about enough when setting up a lathe. Similarly the lathe manufacturers don't think about having a switch that is readily accessible when you around on the other side of the bed.
If you do make a few mods to your set up it will make a big difference.
Barbara Gill
I left about 2.5 feet.So farIhave enough room.
Steven Antonucci
Fixing the remote switch iissue
steven antonucci
Here is what I did to resolve the issue you discussed. It's a magnetic backed switch that I plug the lathe into. The lathe has a switch on the motor at the headstock, and I position this one at the tailstock end. It gets plugged into the wall, and the lathe gets plugged into it.
If I need to turn the lathe off, either switch kills power. Cost me about $30, and requires no electrical skills...
(If you see that black box on the right stuck to the legs, that's it...)
Best of all, the switch has a big, push to kill button that I can hit with my knee if I don't have a hand free...
Steve
Thanks, need to do some thinking!
Bill Howatt
Dick Hines
Re: Thanks, need to do some thinking!
Dick Hines
A kill switch is a good thing to have when hollowing. I put on my PM and use it all the time. I stick it on the side of the bed, at hip height. Then/when something bad goes wrong I can just bump with my hip. No reaching around to the headstock. Which puts you in the line of fire.
If your lathe is powerde with 220 I don't think you can get one of the plug in switches that work with 110.
Carole Valentine
Bill,
Besides the info I emailed to you, I also, like Terry, stand at the back of the lathe sometimes when using the hollowing rig. Having a clear area all around the lathe helps in lots of ways with some other things as well and I highly recommend it if at all possible. Sometimes I turn in reverse, standing at the back, if I have particularly grouchy piece of wood that doesn't seem to respond well in any other way.
