Creative Woodturner Program
Tom Minehan
Anyone using this software? Pros, Cons, Ease of use, etc,etc?
Tom Minehan
Re: Creative Woodturner Program
fgvanatta
I've been using Google Sketchup (free) but this looks like it is a lot more versatile. Think I'll downlaod an evaluation copy and see if I like it.
Frank
charlie belden
What a great design and visualization tool! It allows you to play with possibilities, interactively, in real time - using what appears to be a very easy to use and intuitive user interface. It could really help turners see where and why small changes can make an OK design into a better or great design. And having a picture near or on the lathe of where you want to go, along with dimensions for control points is even better. The icing on the cake is the wood look capabilities - seeing what the visual effect is if you go with side vs end grain. It's not clear whether you can select/define where in the side or end view of the virtual logs you locate the center axis - a critical decision that significantly effects the end results.
It would be great if it also had multi-axis capabilities. Maybe in version 2.0?
Alas, it's only available for WinDoze and not Mac OS or Linux. One can hope.
For $80 USD this software looks like a great bang for the buck. But since it requires using WinDoze as a front end - virtual or not - I'll pass on this one. Pity - it looks powerful.
