Working on the house I bought at Foreclosure that my son wants to occupy. Decided to cover the fascia with vinyl. Home Depot has ready made fascia material made of white vinyl. I ripped it down to the same width as the existing fascia ( 1 x 6). I was planning to nail it on with roofing nails and let the gutters cover the nails. The roofer/gutter guy says it will squirm and ripple and we should use aluminum. Unfortunately I have already bought and ripped the vinyl and do not have the break I would need to do the aluminum. So its on with the vinyl. So now I am thinking of cutting slots for the nails and ripping a little more off so the gutters will be fastened above the fascia. I know there is a punch tool for making the slots, but they want $41 for one locally. Not in the budget for a one shot deal. Tried melting through it with an old screw driver heated with a torch. Did not work well. Left the hole ragged with huge bulging edges. Not what I wanted to encourage free movement.
So I need to cut slots about half inch long and 1/8" wide. Any suggestions.
(Aside to Mac, we've never been formaly introduced. My name is Karl, and I'm glad to meet ya.)
I think a router would be the way to go. I laminate trimmer would be handy. Or one of those Dremel on steroid things that cut holes for outlet boxes in drywall...Rotozip, that's it.
Or maybe a small (3"?) circular saw; like the battery operated ones that come in a duffel bag along with a bunch of other battery operated tools. Make a plunge cut. Maybe with blade backwards or the material upside down.
If I understand you correctly, you only need to make small slots so that the expansion and contraction of the vinyl doesn't buckle the vinyl with temperature changes. I think biscuit slots would be way overkill,and might have a tendency to tear-up the thin vinyl. I would try one of the hole punches used to make holes in leather and other sheet materials. I have one that is best described as being like a pair of pliers, but has a rotating head of different-sized cutters that would allow you to make holes up to an inch or so from the cut end of the vinyl "nailing" edge; a pair of holes (or more?) punched right next to one another in line (making an oval slot) would be all that you would need to accommodate the expansion. See the link below for an image of the tool I'm talking about.
I suspect that if you measured out the hole positions and used a hole punch like this (perhaps backing the vinyl with some heavy, solid cardboard against the punch's anvil) you would likely get clean cuts and make whatever holes you need fairly quickly without the use of jigs, routers, etc. I certainly would try this route before doing a more elaborate method than you might need.
$41 for a slot punch sounds like a bargain. Look on e-bay for one (at least you could determine resale value). Sell the punch on e-bay when you are done.
Find vinyl siding company and rent their punch for a day.
Check the rent all center...
They make leather punches which are oval. Mount the punch in you drill press (don't turn on the drill press) along with a fence and a stop. You could process the vinyl fairly fast.
Having just done the same thing you are talking about, I'd buy the tool and when the job's completed sell, pawn, or auction it off on Ebay... you'll come out way ahead of the time and effort you're sure to put in trying to solve a problem that's already been solved for you by the tool manufacturer.
I bet you will get $41 worth of time saved not to mention the trouble by just buying the tool.
Then when some one says, " Barry how can I cut shots in plastic sideing " you can say " I have just the tool. Only used once and I will sell it to you for $41."
