I need to build a "sawbuck" to cut some logs to cut up into bowl blanks. I am sick of fighting the logs and am going to end up getting hurt. I understand the basic principle and how to construct one and have been scowering the internet for a simple and cheap design and as of yet have not found one i particularly care for. Anyone got any ideas? There is a very functional one in the last copy of AW. It quite possibly will be the winner by default! I use 13" length chunks cut down to 11.5" bowl blanks (12" swing capacity)
Here's mine which is simple and versatile. Two oak 2x2's (1.5" square, actual) screwed to the side of a pine log. The log to be cut is placed with the grain running horizontal; that is, laying on its side. The cut can be made on either end or with the saw blade running between the verticals.
To split a log in half, I place it on the "sawbuck" so that the end of the log is against the verticals. The blade of the saw is then inserted between the verticals so that the log being cut is pulled against the two verticals. You could stand the log on end, but cutting straight into end grain is not the best way.
After the log is split in half, you can knock off the corners as shown here.
If you want to do more "carving" with the chainsaw to round off the blank even more, run a long screw through a short strip to hold the blank as shown here. A screw 3" or 4" long works fine. The screw goes into the center of the blank, which is removed as the bowl is turned, so it does no permanent damage to the blank.
This photo shows a corner ready to be removed, but you can cut on the back side of the blank just as easily.
OK, suppose you don't have a large pine log to use as a base for the "sawbuck." You can sharpen the ends of the verticals (to make stakes) and drive them into the ground. Then place any scrap wood against the verticals to make a base for the log to be cut, to keep your sawblade out of the dirt.
After using this for years, the top of the base log has become concave from letting the saw cut too deeply. Now, I seldom have to use blocks or wedges to hold a log in order to split it in half.
This one's fairly light if made from old dry redwood fence posts, stores in not a whole lot of space, doesn't require that you lift the logette vary high, if at all, and can be used at the tree so you haul the Keeper parts rather than the logettes. Because the spacing is different top and bottom, it'll handle different sized pieces.
The one thing I'd change in the design is to add some notches so you can get a pry bar under the logette while it's on this thing so you can adjust its orientation. It's a lot easier to follow a cut line if it's straight up and down.
My system is less conventional: I have a bearing press with a 10-ton hydraulic ram on it. I place part of the log inside the press, and let the rest hang out the side. It can't move under all that pressure once it is clamped down. Just avoid cutting into the steel press with your chainsaw! Once the blank is cut down some, it's off to the big bandsaw.
I've had and used up several, since I also use them for fire-wood.
I don't like the ones that have "sacrificial" parts, I don't like the ones with pipe or all-thread (I would run the chainsaw into it at least once). I don't like un-treated wood, they rot (I live west of Seattle, it's damp and wet).
Mine is based on the recent one you are talking about. Plus I put plywood gussets between pairs of legs, with a "V" cut into the gusset. The legs are made of treated 2x6, with each angle cut towards a neighbor (I have 8 up legs and 4 that actually touch the ground).
The spacing between the legs varies, to allow me to have spacing for bowls and firewood.
The height is set to allow me to use my standard saw-horses for extra length support.
