Pet urns
Pet urns
Paul Porter
Pet urns
Paul Porter
I have a request to make some pet urns. Anybody know the ratio for pounds to cubic inches for pets? Is it the same as humans; one pound = one cubic inch?
Thanks,
Paul
Re: Pet urns
Re: Pet urns
A local animal hospital might be able to tell you.
The rectangular box in which we received the ashes from our 160 pound Newfie was about the size of a box for 5"x8" index cards (works out to 200 cubic inches, I think - haven't measured) - so that ratio sounds pretty close.
Re: Pet urns
Jim in Burlington Ont.
Re: Pet urns
Jim in River Oaks, Ont.
Yes that is what I used for a reference when I turned an urn for my late Casey.
Take care
Jim
Re: Pet urns
Steve Kubien
Re: Pet urns
Steve Kubien
It truly depends on the crematorium and how they do their job. ***A touch graphic...Some grind and burn, some only burn. Sorry.
Generally you are good with the ratio you mention.
Re: Pet urns
Re: Pet urns
ted okolichany
Most humans it is one cubic inch per 10 pounds of body weight...I done my pets Golden retrievers and cats with no problems. Doing a urn now for a very close friend..
Ted
Re: Pet urns
Re: Pet urns
brent Smith in montreal
I've made a few over the years. Basically I make 3 sizes:
Small 3X4X5 (cats, small dogs, birds etc.)
Med 4X5X7 ( dogs 40-70 lbs)
Lg 6X6X8 ( the largest dog I know of that this size was used for was a Neo Mastiff)
All these dimensions are inside measurements.
Re: Pet urns
Re: Pet urns
Jeff Myroup
Paul,
I make a lot of pet urns and use the same rule for humans. I have found that it is pretty close, and errors on the safe side. It truly depends on the dog breed. I mostly make urns for Mastiffs, and they go around 200+lbs on average. The cremation remains average about 150 cubic inches. I normally have the customer measure the size of the remains when they receive them, since they are in a square container usually.
The one thing a lot of people do not take into account is the weight of the ashes. They can be very heavy. I did not know that until I received my first set of remains to inter. So I make the base a little bigger, leave the walls a little thicker, to help prevent breakage if knocked over or dropped. I also make the opening about larger, to accommodate filling. I use inch and a half PVC fittings for threaded inserts
Re: Pet urns
Paul Porter
Thanks for your replys
Paul Porter
