Glue advice
Glue advice
karl jr
Glue advice
karl jr
I toasted the velcro on my sanding disc holder/mandrel. While I'm waiting for a replacement, I'm thinking I'll glue an interface pad to it. Heat from friction rules out epoxy, I think. CA might melt the foam. Would PVA do the trick? Or maybe spray adhesive? Any suggestions?
KTK
Re: Glue advice
Re: Glue advice
Bernie
I have used spray adhesive with great success
Re: Glue advice
Richard Allen
Re: Glue advice *LINK*
Richard Allen
I have used CA glue in the past.
Currently I use the mandrils from Industrial Abrasives. They work great and the price is very low.
$5.50 for the 2"
$6.50 for the 3"
The good news is that the more experience you gain the longer the hooks last.
Bowl sanding supplies from IA
Re: Glue advice
Re: Glue advice
Terry Scott
I use Selleys Urethane glue brought at the hardware store
Re: Glue advice
karl jr
Thanks all.
karl jr
Re: Glue advice
I just bought a disk at HD.....
Designed to convert a 5" PSA ROS into Hook and loop. It had PSA on it and all you were supposed to do was stick directly on you PSA sander. My sander had a worn out H&L pad, so I sanded it smooth and applied the new disk. I have not tried it yet.
The disk was about $4.95. You could make three or four two inch disks out of it. I did not see a 6" version, but I was not looking.
Re: Glue advice
Re: Glue advice
I use contact cement. I use the same stuff I install formica with however you the contact cement you get at the hardware store in the little brown bottle is the same stuff.
