THE WOODRAT IS BACK!
Thanks for help with grinder
Dinyar Chavda
A couple of weeks ago, I had posted a question asking for help on balancing my grinder.
Based on suggestions, I tried rotating the wheels to eliminate the wobble and the bounce, but my initial attempts failed with my current grinder. I decided to try the Oneway Balancing System, but ran into problems there, as the 1/2" shaft system can only accommodate a wheel that is 3/4 in width, while my wheels are 1" wide. I also turned bushings from hard wood, but that did not help either.
Before springing for a new grinder, I decided to try to combine all the suggestions, and balance the old wheels one at a time on the grinder by affixing washers to the side with superglue and covered them with duct tape (I hope this is not a dumb thing to do!) That got them pretty well balanced, but there was still a wobble. As suggested, I used a combination of shims (just rolled up duct tape) and rotating the wheel, and that got rid of the wobble also. I then dressed them pretty aggressively to true up the wheel, and amazingly enough, the wheels run better than they ever did, and there is barely any vibration to any tool placed on them.
I haven�t done this with the new wheels (I think I can get some more use out of the old ones�that gave Russ a chuckle when I told him), but I wanted to thank everyone who helped me on this forum. So, thank you for all your suggestions, and for helping me learn.
Re: Thanks for help with grinder
I'd be a little concerned about those washers on the sides of the wheels - spinning at 1725 or 3600 rpm, depending on your grinder, if they come loose, you definitely will not need coffee to be wide awake - the sound of the washer as it flies by your head and bounces off the far wall will do it - if you're lucky.
Leo Cuellar
You seem like far too nice a person...
Leo Cuellar
to suffer needless injury, Dinyar. Please at least use a face shield if you persist in using it that way!
Leo
Re: You seem like far too nice a person...
Dinyar Chavda
Thanks for your concern (and what a nice way of expressing it!). I always use my face-shield when using the grinder. Is there an alternative way to balance the wheels, given that I can't use the Oneway Balancing System?
Leo Cuellar
Leo Cuellar
Hi Dinyar. The method that I described in my original post on the subject is a tedious but far safer alternative to gluing weight to the wheel. I copied the following text from my original post.
"One way to balance grinding wheels is to put the wheel on a shaft balanced between blocks. Make sure the wheel rotates freely and is level. Rotate slowly by hand, if there is a heavy spot it will want to rotate to the bottom of the shaft. Mark this area on the side of the wheel. Lightly power grind it with a grinding disk on a small handheld grinder taking care not to remove material adjacent to the bore hole. (Best to set the mounting washer over the side and mark that area with a felt pen to keep from inadvertently grinding it.) Keep repeating the process until the grinding wheel has no preference where it sits on the shaft. Once that is done it will be much easier to get it round. "
If that is unclear, let me know, I can take a few pictures of an impromptu setup for you.
Leo
Thanks, Leo.  Will do.
Dinyar Chavda
