What & How Done. Why Turn It?
charlie belden
Michaelangelo's The David shows David at the moment he KNEW he could and would slay Goliath. The actual slaying was a foregone conclusion - which proved to be absolutely correct.
Gary Knocks (intentional misspelling) Bennett submitted a cube of walnut with a penciled circle centered on each face to a "Sphere" contest - and won.
In both cases, once the idea was worked out in sufficient detail, the rest was basically grunt work - assuming one has the knowledge, skills and abilities required to do the grunt work.
There are folks who have incredibly turning knowledge, skills and abilities who can duplicate almost any turned piece they have seen - but are unable to come up with a design idea on their own.
And there are folks who have all sorts of wonderful and original ideas for pieces - but lack the knowledge, skills and abilities to actually make the piece or make it well.
So here are my question:
Do you prefer to basically make really good copies of other folks designs you seen?
or
Do you prefer to do your own ideas reasonably well?
I've got this idea for a piece and I've worked out the details enough to be able to make it. I've done "horned" two intersecting arcs boxes and successfully laser engraved a low relief carving on their faces. I've done "trumpet" finials and flattened the upper "trumpet" end. And I've done "inset" finials on box lids. So I know HOW to make the piece. I have the tools and skills to DO it and I have done the design for the piece - and even have the wood the design was created to use.
Could YOU stop at this point, satisfied with coming up with the concept, the design details and the HOW,
or would you HAVE to make the piece?
Here's the example of my frequent quandry.
Feel free to use the idea. If you do, please post a picture - and anything you found that's missing in the illustration and description of the process.
