Collaborative Project Idea
Jason Nemec
Hello all,
Doug Trembath posted a request for someone to collaborate with him on a project the other day. I don't think I'm suited to that particular collaboration, but it got me thinking and I have been working on an idea.
Creating turned objects as a group. One person kicks off a project by dictating a loose framework of how an object will be made, then people can "sign up" for a slot based on what aspect of the project they feel they can contribute the most toward.
Each person does their part and then sends it along to the next person. In the end, we might just end up with an interesting object that none of us, individually, would have conceived of. Since there would be no single creator of the object, it makes sense to donate it or auction it for the support of a common cause (Woodcentral forums?? :)
Here's an example of what the slots might be for a project that I would kick off if there was interest in this concept.
1.) Wood selection, roughing, holding tenons/surfaces, initial exterior form
2.) Form refinement, hollowing, parting, bandsawing
3.) Form detailing (carving, burning, beads, etc)
4.) Finishing Part One (Penetrating base colors: dyes, stains, ebonizer)
5.) Finishing Part Two (Surface colors, decoration, metals, pigments, applied elements)
6.) Finalizing (clear coating finishes, oils, waxes, buffing, cleaning, photographing, etc...)
In the case of this list, I divided the project by the steps that I usually take in executing an object. I would expect a different person to chunk a project up in a different way, depending on the type of object they have in mind. This list above is my attempt at a process that will result in an unusual art object.
Two other important details:
1.) There is no failure
2.) There is no deadline
For this idea to work well, people need to feel free to take risks and take their time. If the piece explodes or you spill CA glue all over it, or it "accidentaly" gets lit on fire at some point... no worries, work through it, use the accident as inspiration for a right angle turn to somewhere else. :)
So, is anyone interested in giving this a go? Any ideas how we could auction such a piece? If so, I'll take slot one. If we get six people, we're good to go!
Thanks for reading :)
-jason
Re: Collaborative Project Idea
Randy Gleckler
Sounds like a fun idea..
patrick stein
hi ,
I like to give it a try
patrick
Bob Moffett
Bob Moffett
I would be willing to give it a try.
Jason Nemec
Cool, a couple responses... we could use a few more to make this really work out. I'll wait a little longer and let you guys know.
Also, I had a pretty bad injury the other night and I'm out of commission for a bit... ugh. Carving knife slipped and I cut a big hole in my hand and partially severed a tendon, big bummer. :(
bernie feinerman
I would like to take part in the project.
Bernie
