Question: cutting against the grain
karl jr
In the past while turning natural edge bowls I've been cutting against the grain on the outside from the rim down about an inch. This is to avoid knocking the bark of at the points where it is not really supported by anything but more bark, and avoid tearing the cambium. Shear cut (handle so low I was holding the ferrule) and a sharp Thompson 5⁄8 V-gouge. Yesterday I did a few out of cherry, but this time I did the entire outside against the grain. It worked great. Not only did the bark stay intact, but I got no tearout and no little steps where the cut changed directions, i.e. against the grain and then with the grain. An additional plus was that the ogee I did was very nice and fair, with no corners or flat spots.
Admittedly, the cut felt different. Sorry, I can't really explain how it felt different, it just did.
I suppose it worked as well as it did because cherry is relatively tight grained. Which leads to my question. What woods lend themselves to cutting against the grain? Am I right when I say (read guess here) that it is a function of open grain versus tight grain? I suppose, to a dendrologist this would be the difference between ring porous and ring diffuse.
9 down and 13 to go
KTK
