Photo help needed
Jerry Klug
I used to know how to reduce the kilobytes in my photos by compressing them. I sure dont now. I just spent nearly an hour cruising my computer's programs but didn't see anything familiar for compression. Help, please.
Photo help needed
Jerry Klug
Re: Photo help needed
Bill Howatt
The only place I've seen a compression option (other than zipping the file) is in photo-editing programs. You do a Save As and there is usually a box called Options or something similar that will allow you to adjust the amount of compression when the file is saved.
Bill
Jerry Klug
That isn't what I used a long while ago....but when saving the image as "best for web" it compressed it from 470KB to 57KB. The way I used to do it asked me how much compression I wanted. This works great so I can stop looking. Thanx
bernie feinerman
There is a free program called Irfanview that provides several options that allow you to choose a smaller size to save.
There are at least two types of saves. One simply saves the picture and lets you simply save a percentage as large. The other type of save allows you to specify the number of pixels (H & V) to save.
The program has many other features.
Jerry...
GaryG in MD
Many programs will compress photos to jpegs. First, I'm assuming that you want a jpeg as your output format. It doesn't matter what your input format is. Many graphics programs will convert whatever to jpeg. I use PaintShop Pro, and it has a "jpeg" button. This permits you to save the picture you are processing into the jpeg format, and the resulting "save" window gives you a "compression" option that permits you to pick your output file size to be anything you want from the full size down to something very small. [For computer displays, I typically pick around 100kB, and many sites require smaller. I think WC is now, what?, 80kB? You lose nothing because that's as good as screen resolution. If you want to print on paper, that's another matter altogether.]
Irfanview is a great little program -- I don't use it for processing, but I use it as my "display" program. It's free, very small, efficient to use, and a real joy -- I recommend it highly. Just Google the name and get a download. It does have a compression option if you want to use it for that. If you don't have a more sophisticated photo processing program that will give you a size option on jpegs, that would be a good way to go.
Let us know how you do, Gary
Re: Jerry...
Jerry Klug
Thanks for the input. I just put our club newsletter to bed for the month and had a few photos I needed to downsize so the e-mailed version didn't overwhelm those members with slower servers. I have some time to play with the software now. Thanks again.
Re: Jerry...
GaryG in MD
The other thing you can do to make them smaller in file size is to make them smaller in physical size. They're usually way too big as they come off the camera. I normally reduce them to computer screen size -- that's usually something like 30% linear. That makes them almost ten times smaller in file size even before compression -- meaning you may not even need to compress them after that, depending on what file size you're shooting for. ...Gary
And remember that screen resolution.....
JamieDonaldson
..is in the range of 72~96 ppi, so if internet is the only use you can make those image files very small, and quick to load. If you intend to make prints, resolution needs to be approx.300 ppi.
Re: Photo help needed *LINK*
Ted Calver
I have Irfanview and Photoshop but if you are running Windows XP consider using this for quick fixes. You just right click on the images file name and select resize pictures. It's pretty slick.
Power Toys for Windows
Google "image resize" *LINK*
There are tons of free and easy options for resizing camera images. I do NOT recommend setting your camera to take low resolution pictures. Take the highest resolution images you can, because you need all those pixels to print out nice big enlargements, and, if all you want to do is send them out in e-mails or post them here, you can resize them to whatever size fits the bill.
Search engines are your friend. If you Google "image resize" you'll get a list of options. I've used several and they all work. They only vary in the amount of control you have over the output image and how much you are able to manipulate it (color, brightness, sharpness, etc.) If you don't own Photoshop or Paint Shop Pro or another full-featured image processor, you can download one of the applications that show up in your Google search and use it locally, or click to a website that will do it for you online.
If you want to read a lot of past discussions about this, do a keyword search right here on our messageboards.
Re: Google "image resize"
Jim Rutten
I use Microsoft Office --> Microsoft Office Tools --> Microsoft Office Picture Manager. It works great.
