Ikea Light Jansjo Lights
Wayne Kuhn
Anyone know what the light output is on these light compared to a incandescent bulb? Website says 4.2w total consumption and 3000k color. But just how bright are they?
Wayne K
Columbia, MD
Re: Ikea Light Jansjo Lights
Terry Gerros
If memory serves me correctly, 3000K is pretty yellow. A nice white light begins around 6500K. The problem lies in the fact that I do not believe really white light is readily available in small bulbs. If you could get lights in 10000K range that would be even better...think aquarium lights...those for propagating coral reef tanks. On a side note, T5 and T8 fluorescent bulbs cost less to run compared to T12's and are available in 10000K spectrum. I have 6500K T8's in my shop for daylight lighting and can be purchased at the big box stores. I still have incandescent bulbs attached to my lathe for more focused light.
Nick Tuzzolino
Plenty of good light in about an 8" or so area. Just enough to brightly light pencil marks, knife marks when using chops saw, bends around for direct focus on the bandsaw blade, right on for seeing the line on your work on the disc sander. I have five of them, mounted them on a 2 x 2 inch piece of 3/8 ply and epoxied a one inch rare earth magnet in the bottom.
The color output of the lamps appears to......
JamieDonaldson
......be more white than a tungsten bulb, but I sold my Kelvin meter years ago. The lumen output is well below what I had hoped, so the tungsten bulbs will remain in my lathe lamp fixtures, although I'm considering bundling several LED's together as other have done.
GaryG in MD
Wayne, I wasted an hour in a traffic jam going to Ikea to look at these. The store is a hopeless maze -- I got claustrophobic, and that's not like me -- I'll never go back in there ever again. As for the light -- a total waste of time. In the store lighting, which is just average, I couldn't see the effect of the light on my hand for more than a foot. They are quite dim -- worthless for what I wanted (something for adding light down the axis of my lathe to help see ripples). I went home empty. ...Gary
Jerry Klug
I mounted one on my band saw and it works great. I don't need light to cover a lot of area nor a distance as I can adjust the flex neck to put the light a few inches above my blade/cut line intersection. I thought the color is more blue white but wife says I am colorblind.
I plan to buy some more to task light other tools in the shop, if I can get somebody else to buy them for me. I think I wore out a pair of shoes hiking the store to fetch the light I got.
Cyril Griesbach
Our mini group, the unbalanced six, used one two weeks ago to turn a thin lamp shade and it provided plenty of light inside the shade to aid in determining the thickness of the project. The long flexible neck was plenty adequate to fit into the lamp shade. We did mount it on a home made magnetic base. We were also pleasantly surprised at the whiteness of the light it cast. Considering that we were using it in ways for which it was never intended we found it to be very useful but, of course, your mileage may vary.
D. Hansen
Come on guys. The light is great for what it was designed to be. It is a point light with plenty of power and brightness for limited lighting situations. Its neck will go into places my Moffett light can't approach. It is light in weight and for its size throws plenty of light to supplement regular shop lighting. No it is not good enough for photos nor to take the place of shop lighting but for bright spot lighing in hard to reach places beats the heck out of more expensive items. Remember it is only about $10 I mounted one on a magnetic base and attach it to a sheet of thin steel that allows me to slide it right up to the point of my tail stock if need be. Fro my purposes it is a good purchase.
Wayne Kuhn
Well I bought one yesterday and took to the Towson Woodcraft for turning for the troops. Using it with a midi while turning pens, it did add additional light to the turning. Everyone thought it was a great buy for 10 dollars. The flexible neck is very useful for positioning and it stayed where you positioned it. For small task lighting such as drill press, band saw, etc. I think it is a great buy.
BTW -they are in the lighting department at Ikea which is closer to the check-out than the entrance, follow the arrows on the floor to the check-out and you will find the lighting department.
Wayne Kuhn
Columbia,MD
Howard Norman
I wonder if the layout is the same for all Ikea stores? Never been one so I would have no information on the subject myself. I am thinking about picking up a couple this week when I am in Phoenix.
Wayne Kuhn
Good question. I'm guessing like most box stores they are, with some minor differences. Look on the supporting posts, they have diagrams to get you around the store.
