Folkschool platters
Finally had time to take some quick shots of the platters I made at the Folkschool.
The first one is similar to what Linda Suter has done. We each kind of chose our own design. Since I had not done this exact kind of thing before I was a little at a loss to design it. Now that I've done one I can see many more possibilities. It's maple and Walnut with colored epoxy. I made a different form than usual and then realized that it will sit flat on the table and you can't pick it up. I raised it slightly with a walnut base. I like it now.
This one is more typical of what I do. I sliced a Banksia pod up and the roughly shaped the pieces to fit the groove. Then filled it with Black epoxy. It is Abrosia Maple.
I screwed this one up. I got in a hurry and forgot to seal the edges of the groove with clear epoxy. The black epoxy weeped into the poplar and discolored the wood. Time for a save. At the miniature club that I belong to they showed us how to make scale model Stucco. You take a big dab of paint on the brush and then pick up a small piece of torn up napkin. Then you dab this down and repeat. Many times. It leaves a texture that looks just like Stucco only on the 1"to a foot scale. I thought that might be fun to try on a turning so I mixed up some blue paint and spent about an hour painting. It's gotten some good comments from people who see it.
