So I've decided on the NSK Presto but now see that there's a NSK Presto II. Anyone know anything about that and is it worth the additional cost? Also is there a compressor that's smaller/quieter that a Porter Cable pancake type that will run the NSK Presto?
Regarding the compressor, due to the location of where this will be used is there a reasonably quiet compressor that will run the tool? On the II I see that it's for ceramic cutting.
I believe what you are seeing with the Presto II is the NSK filter/regulator and foot control along with the same Presto handpiece. At a lot higher cost than just the handpiece alone. You need about 1.5 CFM at 35 psi to adequately operate the handpiece, and your current compressor will probably do that.
Most folks that have this handpiece also spend some money on a separate filter/regulator that has an on/off air control valve that the vinyl hose connects to from the handpiece. I've had this handpiece for several years and wouldn't be without it for piercing and carving.
The 35-40 psi should be a maximum if I remember my instruction sheet. You can put your compressor in another area like the garage and run a lengthy air line to your filter/regulator at the Presto.
sil-air compressors are quiet. They are also expensive. Not so expensive is making a cabinet for your compressor. You can expect to reduce the noise from the compressor by about 1/2. Yea, what does 1/2 half mean? Make sure there is good air flow so your compressor doesn't overheat.
