Playing With Fire
charlie belden
Before carbide, before high speed steel, before carbon steel - probably before flint nappers began making sharp cutting edges - there was fire.
If you want remove wood from a specific place - and you don't have edged carving tools - or an electric wood vaporizer - there's still a way to do it - with fire - a small, hot flame, preferably a small hot PIN POINT flame. Char the wood selectively and then scrape out the now much softer charred wood.
Thanks to small pin point flame butane torches you can find in high end culinary supply stores ( used to "brown" / carmelize the tops of custards and merangues (sp?) ) or most tobacco shops as well as most Harbor Freight stores - the tool to carve with fire is now readily available.
Charring wood that needs to be removed has been around for a LONG time. In my youth, cayuco (a refined version of a "dug out canoe) makers in Panama would use fire and hot coals to "carve" mahogany logs into beautiful and easy to paddle unsinkable canoes. Char, scrape, char some more.
A year or more ago I picked up TWO small propane torches at HF, figuring I'd find a use for them at some point in the future. This morning a use popped into my head. "Draw" with the pin point flame, scrape and "draw" some more.
Found one of those little torches this morning, grabbed a chunk of wood - claro walnut cut off - filled the torch with butane , fired it up and started playing with fire - FLAME ON!
In under an hour I've discovered
- that charred wood is indeed easier to remove than sound uncharred wood
- that charred to ash white wood is a heat insulator, preventing wood below
it from heating as much and thus reducing charring below it
- that smooth rounded curved surface are easy to do
- that hard edges and corners are NOT easy to do
- that sand blasting after scraping away the charred wood produces
smooth gently eroded surfaces while keeping the basic shape of the
work area
I doubt I'll pursue this "carving" method since it's not suited to doing on smaller pieces my JET mini limits my pieces to. But for BIG turners, and I don't mean you Bill ; ) , this technique might be something to play with and see if you can use it.
(For some reason, my muse is in a particularly active period, ideas being whispered in my ear a LOT in the last several daze)
