Dye Pen Blanks?
Dave Gelnett
How do you dye a pen blank? Soak it in the dye while in a vacuum? If I dye the wood and then turn the wood it is only skin deep.
Thanks
Dye Pen Blanks?
Dave Gelnett
Thanks
Re: Dye Pen Blanks?
Scott Greaves in Blackfoot ID
So turn the pen blank until you get the final shape and then dye the blank! Most of my past efforts to dye the whole blank prior to turning have ended in failure. But I have been quite successful in adding color to a turned pen prior to applying the finish.
If you don't care of YOU dye it or not, and just want a whole dyed pen blank, buy the color stabilized blanks from the likes of Arizona Silhouette. They put the color in while they a pressure stabilizing the pen blanks, so the color does go all through the blank. But understand that wood has varying densities, so even this pressure stabilizing with color will give you varying shades of color when you turn the blank.
Scott.
I'm with Scott
Steve Kubien
The onyl time I've had success in dyed a blank was if the blank was soaking wet/green first. Then, total submersion. Let the liquid evaporate on its own over a period of weeks/months and you can end up with some neat colours and patterns, but they'll be more washed out than if you dyed the wood after it has been turned.
