Flowers and PR Results
Dave Gelnett
I took your advice and tried putting rose pedals with sellac in a PR solution for a pen blank.
First dried them with my wifes iron and the pedals between a paper towel.(she was shopping)
I put shellac on the pedals before putting them in the PR and they did keep their color. Probably the hardest part was trying to spray the shellac on. I spread them out real nice all over the paper to spray. The first pull on the trigger I knew I made a mistake when all the pedals short all over the shop. Had to put them in a container and spray from a long way off to make it work correctly.
I think next time I need to put more rose pedals in the form since they all try to float to the top or I will need to layer them.
Also found that the PR is a little brittle and it works better to use a scrapper then a skew. Is using a scrapper the normal way to turn PR?
Thanks for all your help.
Re: Flowers and PR Results
Jim in Burlington Ont.
Jim in River Oaks, Ont.
PR is very brittle. I hone a skew and take light cuts to get it round, honing and taking light cuts in cycles, it will tear out and leave chunks missing if you press too hard or have a dull edge that you try to make cut.
I do know a few pen makers who use a scraper as well, I have tried that too, best results were with a fresh burr and pulling towards you with a shearing angle, again the tear out issue.
Hope that helps,
What is PR?
Re: What is PR?
Dave Gelnett
Sorry Poly resin. I used the clear casting resin from Douglas & Sturgess. I think their site is artstuf.com (one f)
Scott Greaves in Blackfoot ID
Hi Dave!
I'm glad the shellac seems to have worked for you. It sounds like you were just coating the flower petals with the shellac and then casting them in the PR. Try tacking the flower petals to the brass tube, re-coating with another shot of the shellac, and then casting the whole thing in PR. You will get better control of the distribution of the petals, will use fewer of them, and may even be able to "artistically arrange" them for the most pleasing appearance! Just use some stoppers in the ends of the brass tubes to avoid filling them up with PR. Good Luck!
Scott.
Thanks Dave- I thought it might be polyester Resin
Dave Gelnett
Thanks that a great idea, have to try it.
Grant Wilkinson
I turn a lot of PR pens. I started using a very sharp skew, but tried a Hunter tool for fun. It worked like a charm and I've been using it ever since. I would think that any of the carbide tools would work equally well. The key seems to be very sharp and a good angle of attack.
