Cognitive Friction and Turning
charlie belden
Cognitive friction is "the resistance encountered by human intellect when it engages with a complex system of rules that change as the problem permutes". Alan Cooper, author of "The Inmates Are Running the Asylum: Why High-Tech Products Drive us Crazy and How to Restore the Sanity" coined the term for use by software and hardware developers. But the concept is applicable to all sorts of other human endeavors.
In a nut shell, it says that the greater the gap between cause and effect, the harder it is to cause a desired effect - or from an effect figure out the cause. As a male, trying to understand just onefemale, I've encountered what may be the ultimate High Cognitive Friction conditions. This person had a magnetic sign stuck on the refridgerator door that said
I know you think you know and understand what I said.
However, you don't understand that
What I said isn't what I meant
HER mother had the same thing on her refridgerator door
and
HER grandmother did as well.
THAT was a contributing factor to our no longer being married.
With that back ground information - let's look at woodturning - single axis turning for starters.
We've got a piece of wood being turned at one end by a motor and perhaps supported on the other end by a tail center. We have a tool rest whose height can be adjusted up and down and on which our cutting tool will be placed. And we've got a cutting tool with a bevel and cutting edge on one end and a handle on the other. The desired effect is a piece that's symetric around its single axis that's shaped as we desire it to be shaped.
Learning the relationship of tool to tool rest, handle movement to bevel and cutting edge and the bevel and cutting edge to the spinning wood all must be understood and used to get the desired effect. To a novice turner, this all seems equivalent to chewing gum and walking - while you're whistling and yodeling at the same time - and doing a graceful pirouette every fourth step. Did I mention going through the alphabet - backwards in your head while you're doing all the rest of that stuff?
The fact that few if any self taught turners are killed while overcoming turning's cognitive friction is somewhat of a surprise. Once the connection between cause and effect is understood, either consciously or unconsicously, the desired effect is achieved without worrying or thinking about the cause. With practice muscle memory takes over - think of what you want - do it without thinking of HOW. Want a cove and you turn a cove - automatically. And once you've got IT, it's assumed to be Common Knowledge. As such it is often not even mentioned - to a newbie turner - because It's So Obvious - and we tend to forget when IT wasn't obvious at all.
But if you teach or mentor new turners you're faced with a quandry. If you point out things that are obviously obvious to the novice - you run the risk of having the novice think that you think he or she is an absolute idiot. However, if you assume the novice already knows something she/he needs to know and understand in order to turn safely - and you DON'T point it out - and he/she DOESN'T know ir - she/he could get injured - or screw up a piece he/she spent so much time and effort doing.
So here's the question:
"What turning technique you are aware of has the highest congiitve friction and how did you overcome it or learn the Cause & Effect?"
You'll get partial credit for identifying a High Cognitive Friction technique and extra credit if I can understand your explanation of how you overcame it .; )
. Now though, since learning that fact I can usually start sanding in the 180-220 grit range.
