Cogitate this venerable wizzards: chatter tool???
LouK
Hello gents-
I'd like to pose a question to you wizzards of all turning possiblities, regarding useage of a 'chatter tool'. I've been turning a series of platters and would like to place a textured inscription on a horizontal flat, adjacent to the rim. I've tried pyrography; while it does provide contrast, does not provide relief and is not particularly uniform, at least by my hand and el-cheapo wood burning tool.
However, I was wondering if one incised or cut out letters in a circulay piece of mylar overlay which paralleled the rim, could one use this as a mask to chatter only the negative space (or inscription)? In some ways similar to the effect of a player piano on a on a spindle roll, in that only the holes (negatives) are expressed and positive element are not.
Would a simple mask cut the chatter, so to speak?
Thanks, Lou in MD
Re: Cogitate this venerable wizzards: chatter tool???
charlie belden
If the chatter tool will cut wood - would the mylar be any different"
Masking works for sand blasting - and air brushing. Probably not
so good for chattering.
Might want to try one of those little vibrating "engravers" to texture
around your letters. Much quicker than burning a lot of little dots.
Rob Wallace
Rob Wallace
In my experience, the chatter tool works best on end grain, particularly on dense, diffuse-porous woods. I agree with charlie that you are very likely (IMHO, almost certain) to simply mangle the surface fibers and mylar at the rim of your piece, and you will see no differentiation in masked vs. unmasked areas. Sandblasting would be the method of choice for what you want to do. Given the pressure needed to generate the chatter, whatever material you use as a 'mask' (frisket, contact paper, shelf lining, etc) will get destroyed.
I would predict failure at accomplishing the intended effect; run the experiment on an expendable test piece to see if it works or not, but don't try it first on a piece you intend to finish.
I do not know if I am a venerable wizard, grasshopper, but you must convince yourself of this with deeds if not just from our words. (Queue Kung Fu theme music...)
Rob Wallace
Sand blast mask
Jorge Casta�eda
The people that make head stones out of granite here in Stonington, use a mask of rubber, it is about 1/8" thick and comes with a pressure sensitive back, the abrasive just bounces.
LASER Engraver
Or sand-blast mask. If you want the letters "positive" you've got two choices in blast-masking.
A. Similar to silk screening, you can apply a thick mastic, like rubber cement to make the shapes which can then be peeled off after the blasting eats away the surrounding wood.
B. Make a precise strip of sand-resistant material like rubber, cut holes for the areas you want cut/textured as Jorge suggested.
The LASER, however, will be far superior, I think, and you can probably find someone in your area who can do what you want or find a service to whom you can send your piece to be done.
Charlie's got it right. Since I don't have access to a sandblaster which would be the fastest way I use my Dremel engraver or simply hand stamp a texture.
I do this on hand mirrors when I want an initial but it could be done on a platter rim. I print the letters off on a copier. Then glue them down.
I turn away any wood I can on the lathe getting as close to the letters as I dare. I use a small router with a 1/4" bit to route away most of the waste and then change to a 1/8" bit to sneak up really close to the letter. Then I hand carve the final clean up of the letter.
I sand this area well and then to apply the background texture I either use the Dremel engraver with a rounded over 1/8" piece of metal, or I hand stamp the back ground with a leather stamp. It takes a lot of time to the leather stamp but looks a lot better. If I was hammering on the rim of a platter I might put something underneath it to absorb the hammer blows and lessen the chance of damaging the rim. A solid base under it would also increase the sharp appearance of the leather stamp.
Re: LASER Engraver
charlie belden
Laser engraving would definitely be the way to go. You'd get crisp letters and a pretty flat and black "field" around the letters. If you go this route, put a finish on the piece, or at least in the area to be engraved. Any soot that gets where you don't want it can be wiped off. Without the surface having a finish on it, and by finish I mean a coat of shellac, lacquer or poly, you're apt to get black smudged on the edges letters that will be difficult if not impossible to clean.
If you have a service do the laser engraving, figure on spending some bucks.
Given the "frugal" criteria - I'd go with a vibra engraver. They're under $15.
Is there anything you don't know?
David Walser
I'm getting sick and tired of your answering questions (and making me feel like you're talking down to the rest of us just because you've got years of experience and are willing to share your knowledge). Just quit being helpful. It's apt to make others feel inferior. ;)
(It's an inside joke, so don't worry if you don't get it.)
Re: Is there anything you don't know?
Lou K
See, I was righty about the wizzard bit, all good answers. As I am looking for a negative or slightly incised letter, think thatI will try the engraver routine. Thanks to all, wizzards & wannabees
charlie belden
Broad range of knowledge - but not real deep ; )
