Veritas - Innovation in Tools
3520B headstock came loose with silicon spray
Aage Rendalen
Aage Rendalen
A couple of days after I posted my original note, the headstock came loose. I had sprayed silicon around its seat and then it began moving again. Molly's horror story had me worried there.
Re: 3520B headstock came loose with silicon spray
Guy Bratt
Hello Aage
I'm glad it came loose without a lot of conflict. I do this every summer when the hummidity rises. I get out some furniture paste wax and wax down the ways. I don't just coat them, I rub off the wax and go at them again untill the last application comes off clean. I'm then good for a year. In your case I would also get the headstock off and do the same to it. Hope this helps.
Good turns
Guy
Dick Hines
Dick Hines
If I have turned anything wet I will move the headstock and spray the bed with WD40 and wipe it down. That will keep the water from working under the headstock.
I do the John Joradn thing every time I turn. Wipe the bed and spindle with WD40. It keeps everything moveing smoo.thly
Wax is not a very good choice............
JamieDonaldson
for a moisture barrier/rust preventer for bedways, and silicone can create a nasty problem if it migrates to a surface on a workpiece to be finished. It often causes fisheyes on anything sprayed with lacquer, so I would suggest a better rust inhibitor like WD 40 would be much less problematic.
Rob Wallace
Avoiding silicone entirely.....
Rob Wallace
Like I was taught in flat woodworking, I avoid anything having to do with silicone products due to the complexities and problems associated with finishing, fish eye, etc. as has been mentioned.
When necessary, I clean the ways of sap, rust (with a rubberized abrasive), and other debris with WD-40, wipe them off with several cleansing washes with mineral spirits, and then seal the ways with Bostik Top-Cote. I also treat the milled bottom of the tailstock and banjo similarly. They look as good or better than when I first got the lathe about 10 years ago. When turning acidic wet woods like cherry and walnut, I first spray a thick protective coat of Top-Cote on the ways too avoid discoloring and pitting the metal. Works well for me.
Rob Wallace
REINASSANCE WAX
Jorge Casta�eda
My mustard monster lives in a plastic covered shed, not much protection for the salt air and high humidity in this island. The day it arrived, after a very thorough removal of the cosmoline, the stuff it comes coated with, I rubbed all shinny surfaces with Renaissance wax and repeated until the rag came clean, then allowed it to dry for a while, it gets a milky look and wiped and wipe the excess until no more came out. I am glad I did,it have not rusted at all and I do turn a lot of green wood, The only con I see is that when sanding, a fine dust collects in the discs under the bed, that hold the tool rest and tail stock, so I keep them clean blowing air and occasionally removing the build up if any.
