thinning ca glue
thinning ca glue
thinning ca glue
eliot d
Is there a way to thin CA glue?
Re: thinning ca glue
I have thinned medium and thick CA using the Thin CA. I have not tried thinning it with Acetone which is the solvent for CA.
Bill Howatt
Thin CA glue should be like water and that's pretty thin. If the problem is because the glue has thickened from its initial state the problem is that the glue is old and should be thrown out. Apparently CA's limited shelf-life can be extended by storing in a refrigerator or a freezer. I've used the refrigerator but not the freezer method probably because the original superglues like Eastman 910 were not to be frozen.
Bill
Howard Norman
Eastman 910
It has been years since I have heard of that glue!
Eastman 910
I thought I read somewhere that Eastman 910 was the first CA. They were playing with long chain polymers and discovered this stuff would stick to just about anything. The 910 is a more refined and distilled version that what we use. I've heard it doesn't burn as much as our amateur brands do when curing on skin. It was used in Vietnam to close wounds.
I've been using the cheap stuff for many years to close torn skin while I was rock climbing.
Terry Scott
Well I wouldn't bother as its as cheep as chips just buy some thin stuff if thick this can be used to mix with dust to full voids
Id suggest that if you try to thin ca down it may weaken its gluing capabilities or alter its set time
Cheers
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA---
Well, I've already gone ahead and ordered some very thin stuff. My question was aimed at what to do , if , say, you had some medium thick on hand, needed some very thin, and had run out, if you could in a pinch thin out the medium somehow. Also , I wasn't so concerned about gluing strength but more from the point of view of using it in thin form to add a kind of plastic-like shine to a particular turning. I know Russ advocates using CA glue as a finish for a certain look.
Re: Eastman 910
Bill Howatt
I think it could be the first CA. My first experience with it was around 1968 and it was almost kept under lock and key because of the cost.
Bill
Re: Eastman 910
Howard Norman
Back in the 1970 time frame when I had direct responsibility for a laboratory we always kept Eastman 910 around for those special requirements where nothing else would work. As noted it wasn't cheap!
My LRRP squad had some sort .......
JamieDonaldson
...CA glue in our field kits for patrols in Vietnam in '68, and I had a punji stake wound in my leg sealed with the stuff. It was in small OD tubes, so I have no idea what it was or that I would have many encounters with it much later in my woodturning life! :b
GaryG in MD
Eliot,
The real (chemical) answer is NO. CA gets thick by polymerizing. Nothing you can do to it will break those bonds once they have formed. If you use a solvent, you will be working with half-dried glue.
What does this mean practically? According to John, you may be able to get away with it for certain limited applications. Do it at your own risk, and report the results to us!
Be a big-time spender -- toss it and get a new bottle at the Club on the 11th!
...Gary
Emmett Manley, Lakeland, TN
The following paragraphs I wrote for our club newsletter may be of interest.
We won�t drift off too far into the chemistry of CA glues, but they are a family of monomers which become linked together, or polymerized, when exposed to hydroxyl ions. Please remember that water is H2O, or HOH, or hydrogen hydroxide, so water provides a good source of hydroxyl ions. There is a huge difference in the setup time for CA glues in my humid garage shop in July (very quick) versus the dry air of an air conditioned studio or my shop on a cold day in December (much slower).
There is not a single cyanoacrylate -- the short chain CA�s (methyl and ethyl) set up faster and form somewhat stronger bonds than do the heavier, or long chain, CA�s. The short chain CA glues are the �thin� glues and the bigger the molecule, the more viscous the glue -- marketed as �medium� and �thick� CA glues. Many of the cyanoacrylate glues are mixtures of the monomers, along with a little acid to keep the glues from setting up until neutralized by the hydroxyl ions. Other thickening agents may be added. Much of this is proprietary information and the adhesive companies do not provide more information than they are forced to disclose.
When I first started using the thin/medium/thick CA glues, I figured they were all the same stuff but just diluted more or less with acetone. That is not the case, the cyanoacrylates are different. You can dilute your CA glue with acetone, but you will just be weakening the resulting bond because you are providing less glue.
Thanks Emmet-most interesting
