CA stain
D. Hansen
Usually when I am going to use CA on a piece of bark that is loose I put a wash of lacquer sanding sealer or similar material on the area. I usually finish my bowls with lacquer so that works for me. today I was working on a cherry natural edge and being lazy, in a hurry, or forgetful or fill in the blanks . . . .did not cover the area with lacquer. I dropped some CA on the bark and of course it flowed nicely on the cambium layer as well as bark. It naturally caused a stain. It wouldn't sand out completely and then I had an aha thought. Grabbed some acetone and an absorbent shop rag and removed the excess CA and the stain went with it. the bark was not effected in the least. Don't know if this is a fix I can use again but it certainly did the trick in this case.
