3520B headstock that is stuck: what to do?
Aage Rendalen
Aage Rendalen
How do you untstick a stuck headstock on a mustard machine? The lever releases normally but I can budge the headstock an inch.
Re: 3520B headstock that is stuck: what to do?
I've seen this happen due to a bit.....
JamieDonaldson
...of rust between the bed/headstock surfaces, almost like they were glued together. Get a bigger mallet and give the headstock a good lick!
spray a little WD40 on the seam first.
George Guadiane
Apply more Mustard
Joel
Ric Taylor
Ruth Niles Can Fix it with her Pipe Wrench...
Ric Taylor
Re: Ruth Niles Can Fix it...no pipe wrench!
Ruth Niles
When this happened to me, I tried every suggestion....except the mustard. : )
The pipe-wrench reference is to the procedure of attaching a length of pipe to the handle of the wrench for mucho leverage. I even jumped on that "leverage" and it didn't work. My faceplate was really, really stuck but I did manage to bend the pipe wrench handle.
I sprayed WD-40, didn't work.
Finally I applied fire, held a small (tiny) torch to the spindle (through the faceplate), then applied ice, then the heat again. It did come loose........however, I also melted the lubricant in the bearings so ended up taking the whole headstock apart to replace both bearings. I now know as much as any tech about The General. : o
