These are turned from a block of wood that is rather daunting when being turned (Even for me l.o.l) as you have no waste wood and a helicopter whizzing around
This one is about 12 inches long
The first step is to select a straight grained timber free of defects
I used Black Maire
The set out has to be spot on
Then I placed on a screw chuck to turn a spigot on each opposing bowl
Before you can turn the spigot there is allot of waste to turn off to start turning the plank
Sort of turned in quarter sections at a time
Then you turn the inside of the bowls and reverse by holding in the inside of the bowl with the jaws so the foot can be turned off
Making templates of the first bowl so you get them the same is important
You cannot see the edge of the plank so you need to be very confident of your tool skills
so you keep a flat surface
I wont say how fast i turned this as you will have kittens
There is allot of air or gap so the speed has to be wound up the bump bump bump
I made another of these with a sphere on each end with a box lid eon opposing sides
Hunted high and low for a picture but unable to find one
I may have to talk to Gorst to see if he can send me a picture as it resides in his collection
If you only made this 12" long, then it must indeed be a scary proposition! LOL. Not the kind of thing I'll be trying until I get my new lathe this spring.
The 1st time I saw a piece like this turned was about 10 years ago by Keith Gotschall of Salida, Colorado. Instead of turning the waste wood off he bandsawed the waste wood and started with a piece of wood that was Z shaped. It certainly cuts down exposure to the propeller.
