Router speed control for grinder
Dinyar Chavda
I need to get a new grinder. I'd get the slow speed one from Woodcraft, but am concerned that if there is a wobble in it, returning it would be a pain, as there isn't a store near me.
HF sells a 3450 rpm 3/4hp grinder item #39798, and there is a store near my house. Can I use a Router Speed Control (Drill Master 4306) to slow down the speed of the grinder, and is it safe to do so?
TIA.
Re: Router speed control for grinder
Richard Allen
Richard Allen
No.
The router speed control is designed to work with "universal" motors. Grinders use induction motors (no brushes and fairly quiet, Universal motors have brushes and are loud).
3600 rpm grinders work fine for sharpening. Use a light touch, work quickly and purposefully.
Doug Trembath
Dinyar, many famous turners recommend a 3600 RPM grinder. I don't. The big thing is quiet, smooth operation. As long as it isn't dancing across the bench, be it from vibration, wheel wobble, etc, it should be okay. You can fix a LOT of wobble problems simply by loosening the capture nuts, rotating the wheel a bit, and re-tightening. I was amazed the first time I did this, at the amount of wobble you can take out of a wheel.
You can also true the wheel to eliminate "bounce" by purchasing a really good diamond dresser, and just barely touching the wheel until you have knocked down the high points. Just like turning, actually. You'll find it MUCH easier to sharpen when you can lay the tool on the grinder face without the tool bouncing on it.
You probably know all of this, but just in case...
Doug Trembath
In addition to Doug's points, I.....
JamieDonaldson
...make a reference mark on the erratic wheel with a marker, then rotate the wheel a few degrees and check until satisfied with the results.
Change the question a bit
Dinyar Chavda
I have a slow speed grinder, on which I was using wheels that had been word down. There was a wobble in them from side-to-side, but it was tolerable because the wheels were small. I now want to put 8" Norton wheels on them, which have a hold of 1". I have sets of plastic inserts to make this fit the 1/2" spindle on the grinder.
I just read that this may be the cause of the problem. The wheel waves from side to side wven when I turn it by hand---one side more than the other. What can I do to try to fix this, as I would rather fix it than buy another grinder (yes, Peter Hyde and I are twins separated at birth!) Are there other inserts that I can buy that might be better?
TIA
Re: Change the question a bit
Don Evans
Yes, there are better inserts and will also help with out of balance wheels. It is made by Oneway and it is their wheel balancing system. Got mine long time ago and cannot remember price range but think it's about $100 worth every penny.
The side to side movement really shouldn't cause any problem, I've never seen a white wheel that didn't have it. It is just the way it is and a new grinder probably will not cure that for you.
What is important is that the wheel FIRST be trued (round) as stated above. It takes practice but if you take a regular pencil, turn grinder on and right back off. Lay pencil on surface so you can move it into the wheel slowly and do this when the wheel is about to stop but still has 6 or so rev's before stopping. You can get it close enough to mark the wheel in one area but not others, You continue to true it with diamond until the pencil marks the wheel all the way round with light, light pencil pressure. Practice this and you will get the idea.
Once wheel is round or very close to it, THEN balance it with the Oneway balancer. This balancer that goes on the wheel is also the insert. So make sure and check the stat's on it and grinder shaft, I think it is for 5/8" shafts only but that may have changed.
Personally I don't see or recomment slow speed grinders for turning tool sharpening, there really is no need for slow speed. Also the slow speed grinder will still have the same out of balance problem.
Don
Carol Reed, Strawberry, AZ
Couple of thoughts.
I bought a slow speed grinder from Woodcraft and returned it because of the wobble - without wheels on it! I really wanted slow speed because I wanted more control and less heat. I had a 1" belt sander mostly unused. I ordered the blue zirconium belts and a leather belt from Lee Valley. I couple of slight modifications to the platen for more stability there and Bob's your uncle. II absolutely love this set-up.
I will be demonstrating this one at my turning club soon.
Second thought: If the Oneway balancing system is out of your budget or you can't make the arbor hole size adjustment with it, try a bronze bushing. No squishing with that. Or turn one out of a really dense word.
Good luck.
Leo Cuellar
Leo Cuellar
It could be that the bearings in the grinder are going bad. If the shaft has excessive end play, that is, moves side to side when you push on it with the grinder turned off, then you may just need to replace the bearings.
One way to balance grinding wheels is to put the wheel on a shaft balanced between blocks. Make sure the wheel rotates freely and is level. Rotate slowly by hand, if there is a heavy spot it will want to rotate to the bottom of the shaft. Mark this area on the side of the wheel. Lightly power grind it with a grinding disk on a small handheld grinder taking care not to remove material adjacent to the bore hole. (Best to set the mounting washer over the side and mark that area with a felt pen to keep from inadvertently grinding it.) Keep repeating the process until the grinding wheel has no preference where it sits on the shaft. Once that is done it will be much easier to get it round.
John Jordan
Doug is 100% right. All you need to do is loosen, tighten, shift the wheels-they WILL run true. I've worked on and trued dozens of the Woodcraft grinders-the shafts are not usually (though some have apparently been) bent and don't wobble-it's play in the bushing/flanges. You can make or buy better bushings, but you don't have to. Just keep at it until they run true. Even the Baldor grinders will have the problem, though usually not as much as the quality of the flanges is much better, but they have to be fiddled when installing new wheels.
It's a good buy.
John
right on john
bob davis
john has THE answere
Thanks everyone
Dinyar Chavda
Thanks, everyone, for all your suggestions.
I'll play with the existing plastc bushing and the flanges first, and see if that works.
Out of curiosity, where can you get bronze bushings from?
Carol, this is a dumb question, but my belt sander goes down towards me. Did you have to reverse the direction of rotation, and, if so, how?
Thanks again.
Re: Thanks everyone
John Jordan
You don't need a bronze bushing, turn a wooden one. :)
John
Juergen
The 1st thing I always do with new wheels is to turn my own bushing out of a dense hardwood.
Juergen
Re: Thanks everyone
don lewonczyk
I'm not Carol but you don't have to reverse the rotation on your belt grinder. If your not free handing the sharpening and you want consistant results you need to be able to set your tool rest with a gage. I have a sorby and all the angles are preset, really cool, and the belt runs up, that way your gouge, skew, etc doesn't dig into and ruin your belt. DonL
Re: Thanks everyone
Sometimes I wonder where my replies go to?!? I thought I answered this one yesterday. Oh, well.
I cheated. I had a motor that allowed me to reverse some leads and thus change the rotation. Now the belt runs "up."
It is an old Delta 1" belt grinder. I also bumped out the platen by inserting a 3/4" thick piece of double sided Melamine behind the belt. It is attached to the metal plated with two rare earth magnets. The top and bottom ends are rounded to ease the belt over them. That was the only way to get the right angle(s) with my Wolverine.
I'd have to go look what I did to accommodate the rest. I don't recall that I did anything, but I can go look if you like. Maybe even take a picture, though I haven't posted on on this forum for some time. I would need to be retrained!
