Mountain Mahogany
Doug Adams
Has anyone had any luck drying this wood without a lot of cracking
Mountain Mahogany
Doug Adams
Re: Mountain Mahogany
robo hippy
I have been through a lot of it with no problems. You do need to seal it if you have logs, and when you cut it for turning, you need to turn it right away. I do use the stretch plastic film for keeping it if it is going to be a few days. Movement is very minimal, and it is the only freshly cut green wood that I have turned where I needed to wear a dust mask, and I harvested in early April, just outside Las Vegas. If some of the heart wood is black, that does tend to check more easily than the red colored wood. My log stack has been outside for 2 years, and there is very little checking. Probably is wetter than when I harvested it.
robo hippy
Doug Adams
Thanks
I just cut a bit and had problems with checking I will try your suggestions. I am in St George and cut it near Cedar City
Doug
