Flowers and PR
Flowers and PR
Flowers and PR
Dave Gelnett
Has anyone tried to put flower pedals in Poly resin to make a pen blank? I tried it this weekend but all the pedals turned from red to white after the PR solution dried. How do I keep the original color?
If you try this make sure you have the air moving, the PR smells worst then lacquer. I cant lose any more brain cells..
Thanks
Re: Flowers and PR
Re: Flowers and PR
Dave I played with it for a short while and may try it again soon. All of the methods I tried changed the color of the leaf, and some fabric that I tried. I thought afterwords about pre coating the material with some other product. Krylon Fixatif is one of the products I want to try because it changes most thing the least when you spray it. For leaves I think possible spraying shellac is a possibility. I may be wrong but I think spray would work better because it might not penetrate and change the color as much.
If I get a chance I'll try it this week and see.
Re: Flowers and PR
Re: Flowers and PR
Ted Evans
If you use lacquer, you may wish trying a few very light mist coats to start with, once they have set up, then go a little wetter coats until the desired affect is achieved. This is the way I used lacquer over plastic without deforming the plastic. Do not know how it would work on petals or leaves though. Ted
Re: Flowers and PR
Re: Flowers and PR
Scott Greaves in Blackfoot ID
I'm with John, I would try the shellac. It would do a pretty good job of sealing the flower petals without changing the colors too much. You can still expect some color shift due to the heat during the curing process of the PR, but I think your best bet is to try the shellac. Good Luck!
Scott.
