Captured ring tool
Captured ring tool
Captured ring tool
I decided to make a more normal size mini goblet. This one is about 2" tall. Made from a glue up of 9 pieces of wood. Walnut, Bamboo, and Mahagony. This is the reason for doing the mini goblets. It teaches you to do the finer details on the larger work.
I needed a captured ring tool for this size ornament so I made one. Took about 15 minutes. I heated the end of a piece of drill rod and hammered it flat. Then ground the outside to shape. I traced in the inside and then cut out some of the waste with a hacksaw. Then used a round file to shape the inside.
Re: Captured ring tool
Terry Scott
Hi John The segmenting in this works well ,great idea to practice crispness on smaller work I must remember that
You may already know this but if you wrap some sandpaper strip around the stem and hold on with tape each end you can then sand the inside of the captive rings
Cheers
Terry I did that but obviously I didn't sand that one ring well enough. OH well there's always a next time.
Leo Cuellar
Leo Cuellar
Really nice goblet John. I hate when my camera picks up details my eyes can't see. What do you use to sharpen your micro tools?
Leo This one was done with a 1/4" spindle gouge and my new captured ring tool. Those are sharpened in the normal fashion. My micro tools are sharpened and shaped under the stereo microscope. 1200 grit looks like your sharpening on the sidewalk. The hardest part is stropping to get rid of what looks like huge burr under the scope. I do that on my wet wheel grinder's leather strop. I can't see the bevels so I mark the handles with 2 marks that correspond to the bevels on the skews. Then just strop both sides. Gives me a mirror finish and super fine edge.
Leo Cuellar
Amazing, Thank you!!!
Leo Cuellar
