Roughing gouge
Clyde Collier
Bought a new gough and was wondering what is the preferred bevel angle. Mine is groung at 30 degrees above horizontal. Thanks
Roughing gouge
Clyde Collier
Re: Roughing gouge
Terry Gerros
I grind my SRG at 40 degrees. Cuts very nicely.
Re: Roughing gouge
I also grind mine sharp about 40 tto 45 or so. I depends on how you use a roughing gouge. If all you are using it for is taking things from rough to round then an angle like 60 ot 80 is better. It will hold a somewhat dull edge for a long time. ONe of the men who showed me how to turn sharpened his this way because he turned hundreds of spindles and didn't want to waste time sharpening that tool.
I rough shape with the tool and then fine tune the shape using the upper part of the U like little skews. consequently I like having mine a lot sharper so I can go right from there to the skew for the final few passes.
Re: Roughing gouge
Terry Scott
Johns advice is spot on
Re:Let's not forget that ......
JamieDonaldson
...it is a SPINDLE roughing gouge, and I grind mine to approximately 45 degrees.
Jamie's right- would not recommend using it
for bowls. They simply weren't designed for that and I have seen an awful lot of them bent or broken by people using them to rough out bowls. Better to get a 5/8" bowl gouge for that.
Re: Jamie's right- would not recommend using it
Clyde Collier
Thanks,40-45 degrees it is.
Geometry problem
steven antonucci
The sharper the edge, the lower you have to hold the handle to be on bevel...
Grind it to an angle that is comfortable and compatible with how you stand at the lathe...
S
Re: Geometry problem
Gordon Seto
Raising the tool rest height would compensate for the bevel angle.
I agree with Gordon. Both of you are correct to some degree. Raising the tool may change where your cutting on the piece but does change where the handle will fall on your body. As someone who does almost all my turning using my hips to control the cut I move the tool rest a lot. Steve is of course correct also because changing the angle of the bevel changes where the handle will be in relation to the axis of the piece.
Gordon Seto
We are talking SRG here, it is spindle turning. For a bevel supported cut, the cutting is always at the tangent of the spindle and the bevel. The cutting point may change in relationship to the index of the lathe axis, but it doesn't matter because it is a circle. When the diameter gets smaller, we have to raise the end of handle or lower the tool rest height. We may choose to adjust the tool rest height after moving it closer.
When I change tool of different nose angle, I can adjust the tool rest to allow the end of the handle to fall to the same height. Is my assumption right? Otherwise guys with high waist line would prefer to use tools with larger included angle.
Gordon
