Working on my speed problem...
Leo Cuellar
Leo Cuellar
I decided to go in a different direction. I checked into the price of a new spindle for my lathe and was shocked to find out it was very affordable, about $35. I happen to be one of those hoarders... so I have lots of parts to tinker with. :D
I'm still working out configuration details, but this should get me down to about 200rpm or so. Which should take care of my burnishing problems. I'll build a detachable platform to mount it on the shaper I rarely use. Now if I can only remember where I put my twist-a-link belt...
The bummer part of this is that the new drive pulley I need for my lathe is still a month out on back order. I'll have to live with some vibration at high speed for a while yet :( but at least I got it moved back to the other side of the shop and bolted to the floor.
Re: Working on my speed problem...
Steve Kubien
Steve Kubien
Where did you get the spindle? Do you have a part number? I've got some tinkering in mind....
Leo Cuellar
Leo Cuellar
Hi Steve. I got that particular spindle from Grizzly. It is from a G0462 lathe. 1" x 8tpi w/ #2 morse taper, roughly 9 & 3/4" long. Part # P0462033, lists for $33.25 plus shipping. I can't tell you exactly what size bearing it takes, my metric calipers are at work, although I would guess 24mm. I just happened to have some 1" pillow block bearings stashed and shimmed with a few thousands of brass sheet. Since it will be turning at very low rpm, I don't think vibration is going to be an issue. It is only intended to be a sanding machine.
They do make bigger models of lathes that appear to have longer shafts, however they don't have any larger diameter than 1 & 1/4" x 8tpi. I don't live very far from the Bellingham showroom so if you need further info I'd be happy to help.
Leo
Bart Leetch
Leo
Where did you get a pulley to fit the shaft & is it a step pulley?
Leo Cuellar
Leo Cuellar
Hi Bart, the two step pulleys are from a Jet drill press conversion that I picked up at a closeout sale from a local hardware store. I mounted the one in a 3 jaw chuck and bored it out on my lathe with a drill bit just undersized of the actual dimension. I used a carbide metal lathe tool mounted in a piece of 1/2" pipe, freehand, to bring it to the final dimension.
Steve Kubien
Steve Kubien
Thanks Leo. I will let you know. Very kind of you.
Bart Leetch
Thanks Leo.
