more options for seated woodworkers *LINK*
john lopez
I just found out about this line of power tools
called Access by General
http://http://www.general.ca/site_access/access_en.html
john lopez
link didn't work. here it is *LINK*
Re: link didn't work. here it is
OB OBrien
I looked at the Access lathe on the General site and don't see anything to help a sitting woodturner any more than any other lathe on the market. I turn sitting down and am very interested in such a machine.
This one doesn't fit.
OB
Steve Kubien
The only thing I see is the spindle height. Isn't 39" kinda low? I mean lower than normal? I could be very mistaken on this.
john lopez
Steve,
39 is low.
I turn from a sitting position and my center is at 45 inches but that is just me.
OB,
it looks like there is clearance under the bed for a user's legs.
As you know many lathes don't allow for that .
I think any lathe manufacturer that markets a more accessible machine is noteworthy.
I found a recent addition to the Vicmarc line too.
http://www.vicmarc.com/default.asp?contentID=718
John thanks for posting the correct URL .
I tested it last night and tried to edit but was stricken with password amnesia
and could not correct it.
Apologies to all for wasting your time with that.
John
Another solution
OB OBrien
Yeah John. That Vicmark is an advantage. A lowered lathe with it open under the ways is also a help. I have just cut off the stand and lowered the stand for a Jet mini and it works fine. Can't get my legs under it but sort of sit sideways. I do the same when using standard size lathes. Used to take a stool with me when doing demos at clubs away from my shop. Going to get back into doing that again as I really enjoyed showing folks different tricks and tips.
Cya
OB
Re: Another solution
OB I built a stand for a wheelchair bound student many years ago. It was designed for a mine lathe. It was basically a 1x12 bolted to 2 stands and we tilted it forward just a little so when he slid under it the lathe was in a more comfortable position. It was still higher than we liked but couldn't get it lower due the height of the wheels on his chair. The angle did make it more comfortable to use the gouges.
