I was given a piece of padauk and I'm turning an 8" bowl. I've never used that wood so I decided to experiment with some finishes on the cutoffs. I've tried Danish oil and wipe-on poly (my customary finish) and they both darken the wood a LOT so the interesting grain is pretty much gone. I like the way it looks unfinished but I'd like to seal it, at least. Any suggestions would be appreciated.
Nope. Every finish I've tried darkens it and then with age it goes a dark burgundy. Even darker than it is when you first put the finish on. I'd try Krylon Fixatif. I don't know if I tried that or not and it changes wood about the least of anything I've tried.
Ed, water based laquer should leave it the original color except for whatever darkening you would get with any liquid. But, as John said, the color is going to darken over time to a chocolate brown no matter what finish you put on.
it seems like all the nice colored woods we like to use, lose that color with age/sun
I made a nice looking padauk nut bowl for my mother, she put in someplace were it was in direct sun for several hours each day. Within six months is was a dark chocolate brown...except for the underside
The darkening of Padauk can be used to your advantage. I have finished the wood with the usual sanding sealer then a light waxing before rubbing Gold Gilding paste into the pores of the grain, removed the excess with another waxing and then buffed 24 hours later with Beall wheels and Carnauba.
As the timber oxidises and changes colour the Gold becomes slowly more intense against the darkening background.
