jet 1442 rpms
jet 1442 rpms
jet  1442  rpms
ed hoxter
is it possiable to slow the speed down on a jet 1442 vs ?? if so how ?? ed
Re: jet 1442 rpms
Tim Boger
Re: jet  1442  rpms
Tim Boger
I have the same lathe and removed the speed setting dial / handle and drilled another hole for the locking pin to engage when the dial is turned to encourage a lower RPM setting .... other that a slight mis-alignment of the hole (my fault) the plan worked well.
I'm interested to read what others here suggest.
Re: jet 1442 rpms
Re: jet  1442  rpms
John Altberg
I made the same modification on mine, including the misaligned drilling! Nothing a second hole couldn't fix.
