REAL MILK PAINT
For Mike reply to texture How lots of pictures ?
Terry Scott
The grid pattern I have used numerous times and find it to be very effective
With skew mark off an equal width set of rings then with a scaple type burning blade cut in individual lines 5 one way 5 the next
Yep each ring on these 26 inch platters takes about an hour and a half
Then the back that takes far longer
It has been said Texture is my My thing
I aptly call this series Time Wasters
This Piece (drum Roll) I called Imperial Presence
Turned in the rectangle it is a little on the large size as it 1s 1100mm long close to 4 foot The legs were turned on seven axis
Many hours were done texturing the top surface then a mix of copper gold and silver leaf was applied 8 packs of 20 sheets
The tips of the horns or legs were bound in copper
I really enjoy making large platters but unfortunately they will only sell for just under the 2k mark ,so I rarely make a half decent hourly rate . Still I am fortunate that this stays my hobbie and I have a real job
If I went full time id be sure to lose my creative drive
Enjoy
More platters can be seen at www.timberly.co.nz
Re: For Mike reply to texture How lots of pictures ?
Steven Antonucci
productivity suggestion
Steven Antonucci
If you do a lot of those 5x5 cross hatching patterns, couldn't you save a boatload of time if you had a "5 line tip" for your burner? I assum you could just get a bit of brass and file it to whatever shape you need to make the 5 lines?
Might be a bit of setup work, but I bet you'd earn it back on the first platter?
S
Better than I originally thought.
Mike Foster
Wouldn't have guessed the texture from the first photo, I thought it was kind of spiral outward curved carving. The bottom just makes it all the more special. Great piece.
Mike
A fine product takes time
THanks for pointing this out Terry. There really isn't an easy way to make an exceptional piece other than taking all the time necessary to do it right. You point that out whether you intend to or not. Your work is excellent and you obviously take the time to do it right.
