8 oz containers
8 oz containers
8 oz containers
dick gerard
Hi all!
Once again turning to WC for help/advice. I am looking for some containers (8 oz) that will be used to hold the Transtint Mixes (alchohol as solvent). I'd rather not use glass, but will if I have to. Does anyone know of any sources for plastic containers, preferably clear, that will not dissolve when holding denatured alchohol?
Dick
Re: 8 oz containers
Rob Wallace
Re: 8 oz containers
Rob Wallace
Plastic bottles made of polypropylene or polycarbonate would probably work OK with denatured ethanol, although the bottles may experience some staining. I've stored 95% alcohol (ethanol) and 100% isoporpanol in polypropylene bottles in my lab for several years without problems.
Rob Wallace
Re: 8 oz containers
Re: 8 oz containers
Look at the Chemistry supply houses. That's where we bought the ones for out Darkroom. Wish I could remember the name of the place but it probably doesn't matter because there are ton's of them online.
You might also check out Dick Blick's art supply.
Re: 8 oz containers
Walt Bennett
Re: 8 oz containers
Walt Bennett
I've used Lake Charles Manufacturing for squeeze bottles, large test tubes to line bud vases and several other items for years. They're as cheap as I've found and have great customer service.
http://www.lcmlab.com/
Re: 8 oz containers
Re: 8 oz containers
Nick Tuzzolino
I get mine at Sally's Beauty Supply. Probably local for me, but a beauty supply store will have every small size and style you can imagine;. Very reasonable. Like $1.59 for 8 oz
Re: 8 oz containers
Bill Blasic
Re: 8 oz containers
Bill Blasic
I know that they are glass and not plastic but I use baby food jars. They are small so I can mix small amounts but easy to get the dye out of.
Bill
Re: 8 oz containers
Re: 8 oz containers
Don Evans
Here is one I've used, lots of stuff from bottles to sheets of different plastics.
http://www.usplastic.com/
Don
Re: 8 oz containers
Re: 8 oz containers
Steve Worcester
the container store has naglene (semi-transparent plastic) jars pretty cheap too. I use them for all sorts of solvent based storage.
Re: 8 oz containers
Re: 8 oz containers
Dave Gelnett
Try using the CA glue bottles. I have used the small bottles with the long thin nozzel to apply lacquer to dents in the finish. (Steven Hatcher's recomendation)
Re: 8 oz containers
Re: 8 oz containers
Doug Turner
My wife dyes her hair about every 3 weeks and one of the ingredient bottles comes with a spout and cap about 3-4 oz size which is pleanty for diluted transtint dye. These containers hold acetone, lacquer, paint thinner, alcohol and anything else without deteriorating. Unfortunately they are not transparent, but I label the contents with an indelible Sharpie pen. You might want to check close to home...
