Floor support
Floor support
Floor support
MMann
While we're talking about outboard toolrests (see other thread) this brings me to thoughts about the floor. The lathe sits on a wood floor, 2 layers of 3/4" over 2X12 16oc spanning 12' from wall to large center beam. There is a 3' crawl space beneath the floor. I get vibration in my lathe with large unbalanced pieces. Short of reframing the floor and pouring a huge concrete pad for the lathe, any ideas? I've thought of adding another "frame of sorts", very stiff, beneath the existing joints and beneath the corner of each an adjustable jack post sitting on a concrete pad, these would be relative to the four corners of the lathe. Sort of isolating this part of the floor and supporting it independently. My concern though, will I get vibration anyway simply because the support, other than the posts and pads is wood.
Re: Floor support
Re: Floor support
Bill Howatt
I have a 20" General bolted to a concrete floor in my basement. It will vibrate with large unbalanced pieces but that is easily corrected by turning down the speed via the electronic variable-speed knob.
Stiffening the floor might be a good idea but it won't stop the vibrations if the unbalanced piece is spinning too fast.
Bill
Re: Floor support
Re: Floor support
If your lathe isn't sitting perfectly flat on the floor it will vibrate. My lathe is on concrete and has adjustable feet. After leveling I try to "feel" the tension on each foot as I adjust them. What I'm trying to do is get equal pressure on all 4 feet. That seems to reduce the vibration considerably. so what I'm saying is it may not be your floor.
Re: Floor support
Re: Floor support
John Veerkamp
One easy way to stiffen the floor is to install cross blocking between the joists if not already there. Cut 2X12 and install between the joists every 3' in an area about 8'X8' under the lathe. Too often in modern construction , cross blocking/bracing is skipped to save money.
Re: Floor support
Re: Floor support
MMann
The joists are blocked and the lathe is level in both directions. I'm guessing it's a matter of flex in the wood (thus my thoughts about additional rigid support) as well as not enough mass in the lathe to overcome the unbalanced pieces which are somewhat large and quite unbalanced. The lathe is a Oneway 2436, I suppose I could add sand to the tube. I understand about speed and vibration, I'd just like to get a bit more rpm without the vibration.
Re: Floor support
Re: Floor support
Keith Newton----Little Rock, Arkansas
Before building my big lathe, I recall trying almost everything to dampen the vibration. One thing that I found to be useful for determining problems, was to whack the lathe with a big rubber mallet in various places while holding my other hand in other places. If you can feel vibrations beyond the initial strike, you know there is room for improvement.
You ought to try that before you add the sand, which I understand has a damping effect. Also, adding more weight to the tailstock end will help with the tail wagging the dog factor.
If you are really pushing the limits, I would be thinking about adding a plate behind or between the faceplate and work, that would allow you to add counter-balance weights, that can be adjusted as the project changes during turning.
Re: Floor support
Re: Floor support
Ted Evans
Years ago I read someone saying that putting hard rubber pads on my 900 lb mil machine would reduce vibrations and make it run quieter. I was reluctant, because to my memory they were about $15 a piece, however, I eventually installed them and wow, what a difference.
Now, I have a little Jet 1642 lathe that I need for it to be mobile. Not being blessed with an abundance of resources, I decided to use a less expensive set of casters with good locks. Even with the small items that I was trying to turn, there was just too much vibration and I had to put blocks under the lathe, therefore, I did what I now wish I had done in the beginning; I purchased a set of Stabilizing Casters from Great Lakes that I have seen others recommend. I thought not only is the lathe mobile, it also has leveling adjusters now.
What I have found, at least where my lathe is located, there is no need to use the leveling feet for leveling nor for stability. The levels are adjusted to give just enough space to not interfere with the mobility and I truly believe that the lathe is much more stable and has less vibration now than when it was setting on the original pads on the legs. It is surprising how fast I can spend a blank when initially roughing, considerable faster than before. This is on blanks in the 8 to 13� x 3 to 7� range that have been band sawn. I have yet had the need to use the levelers, perhaps with a larger, heavier more unbalanced blank, the need will present itself at some point in time.
That being said, none of what I have written is a recommendation for others, it is only my personal experience.
Ted
Re: Floor support
Re: Floor support
Mike Brazeau
Is the lathe sitting parallel to the Joists? If so,maybe better cross them? Have a friend with a 2436 in similar circumstances and has the same problem. Really only a problem with green blanks. He has not attempted to cure problem, and now rarely turns wet wood. We have a similar issue with a kitchen island with 500 pounds of granite as counter top. When anyone walks around it, harmonic vibrations are created and the floor bounces. I have installed 3 three ply short beams of 2x6 with jack posts under them and had some improvement but didn't eleiminate it.
