Powermatic Freestanding Toolrest
MMann
Does anyone here have a Powermatic freestanding tool rest or have you turned using one? If you have I'd like to hear your comments about it. In particular I'd like to hear about its stability when used with heavy, large diameter work. Thanks in advance.
Re: Powermatic Freestanding Toolrest
Rob Wwallace
I'd also like to know about this - and what mortgage rate you got when you bought one!
Rob
MMann
In addition to the stability I'm wondering about the strength of that "arm" which holds the tool rest. I have visions of that thing snapping.
Nope, Didn't Snap
George Guadiane
I have one, I have used it very infrequently, and given the chance, I'd sell it and buy the bed extension... HOWEVER, it works perfectly. There is a little bounce, but I have wooden floors in a 100 year old barn.
Re: Nope, Didn't Snap *LINK*
I have used an older one. Worked well but if you get to aggressive with the tool at a bad angle it will pull the rest into or at least toward the work. It is very heavy which it needs to be. I built one of the rests using a truck wheel. It doesn't work worth a darn. I think it needs much more weight. I'm going to fill the wheel with concrete and see if that works.
When I had to turn a large platter I didn't have anything like a free standing tool rest. However I did have a drill press. I removed the geared lifting rack and turned the table around 90 degrees. The clamped a piece of 3/4" bar to the table and moved it up to the correct height. Worked well enough to get the job done.
I prefer the Vicmarc outboard tool rest that is bolted to the lathe. I have tried a homemade version a friend built for his lathe and it is very steady.
http://www.vicmarc.com/default.asp?contentID=545
MMann
Perhaps we can work something out if you email your asking price. By the way the bed extension you're looking for, is that for a Powermatic or some other brand? I happen to have a 17" Oneway extension that I'd part with.
MMann
Thanks for the reply. I haven't seen the Vicmarc extension in person but in the photos I get the impression that it would interfere with large diameter work.
Attached Outboard Toolrest
Steve Harder
On my Nova 1624 I went for the homemade approach. Total project cost if you bought everything new would be around $60. I already had the pipe so I just needed to buy three Kee Klamps for $30 and do a little welding and pipe cutting.
Google "Kee Klamp" - these fittings make an adjustable but very strong and solid connection between the pipe sections - be sure to get the correct size for pipe you are using.
I used 1 1/4" ID black pipe for most of the structure and then reduced to 1" ID - which makes a slightly loose but nice fit with existing toolrests.
(These are the "ugly photos", I'll grind the welds and paint it after the tweaking.)
The upright under the toolrest sits on the floor - it resist getting pulled into the work. No, it's not as rock solid as the banjo - but with thoughtful tool use and reasonable expectations it allows me to expand the capability of my lathe.
Adjustment requires loosening several hex head screws.
The head on the Nova was not swivelled for these pics.
Re: Attached Outboard Toolrest
MMann
Well Steve I must admit that you have me thinking now. I've been skeptical of home built rests but yours, being attached to the lathe may do the trick for me. The "Kee Klamps" look to me like a product that I'm familiar with called SpeedWell fittings, used in handrails. Thanks for the mental stimulation!
Bernie
I used the stand with my old 1642 Jet lathe.
I turn large platters 18" to 28"
I never had any issues with the stand except
I had to glue rubber pads on the feet since my
shop floor is cement.
Steve Harder
Anytime you extend the capability of a power tool you need to be judicious in how far you push the envelope. But this addon is a pretty rigid structure and I expect it to work well as long as I use it carefully.
I'm sure the kee klamps are available under other names - I have seen them used to build some very large and substantial structures where safety and load ratings were very important.
One unexpected usage - I've used this to get at the headstock side of a "max size" bowl when my banjo wouldn't fit under or reach around. (With the Nova headstock not swivelled.)
Bed Extension
Jorge Casta�eda
MMan,
I did consider the Powermatic Freestanding Toolrest, but then decided on the bed extension for several reasons, I can turn up to 39" platters, haven't done one yet but 24" yes, and it was a good experience with no adrenaline surges.
The extension bed can be mounted flush with the bed and then you can do stuff like newel posts, or can be mounted on the alternate position, 9" lower than the bed. Then you can turn big. When you buy the bed extension, it comes with an extension for the tool rest as well. it work fine if you do not get too aggressive, as there is a little spring to the rig.
The best part is that it does not take a larger footprint, and it was actually cheaper than the standing tool rest
