Wax in a hole on a burl
Bruce Newman
Turned down a sweet burl tonight and decided to leave some of the hollows on the outside of the burl as "cut in's" on the outside of the bowl. The question is how do I get the wax off of the outside of the burl? Hair dryer, propane torch?
Thoughts?
- Bruce
Re: Wax in a hole on a burl
Dave Gelnett
A small brush works well but I like to take my wood burner tip turn up real hot close to the wax. Its kind of fun just make sure the wax does not run down the out side of the turning.
I have used this method to remove dust that collects on the bark around the rim of a natural edge. Just get the hot tip close to the dust and it is gone. Dont get to close and mess up your finish.
How about a heat gun? Heats hotter than a hair dryer and you don't get in trouble with the significant others in your life.
Steve Worcester
If it is the wax from when it was waxed to seal it and dry, then probably a heat gun and some careful backup with a paper towel to help move it away and keep it from dropping into the void (assuming there is one). You may also get away with something like acetone, but it may also discolor the surface.
If it is an area that was waxed as a finish, use a Crest spin bush if it is a soft wax (like a paste applied with a towel) as oppose to a carnauba applied with a buffing wheel. Much harder wax.
