Plain Bowl 2
Plain Bowl 2
Plain Bowl 2
Terry Scott
I have been hunting through my burl stash for another suitable to make something similar to Plain Burl One
The support ring system I have developed sure takes out the flex so I can turn these as thin as I like
This one is 3or 4 mm
The wings may appear uneven but this is the taper on the natural edge making them look thicker
Sanded with medicinal Paraffin Oil then lacquer finish
Be assured ill be hunting out more of these dry hard stubin burls, like a chocoholic in a chocolate shop these things are
A bit of a trick to get the 3 feet right so it didn�t tip over
Also bigger than the photo portrays
Every time I turn one of tehses burls I feel blessed that somehow I was chosen to be the one to craft and bring to life what lies within Thanks mother nature !!!
Comments welcome
Re: Plain Bowl 2
Re: Plain Bowl 2
Toney Robertson
Very elegant.
I am amused that you consider this bowl plain. I guess it depends on your definition but IMO it is anything but plain.
Re: Plain Bowl 2
Ring system
Terry, I must have missed your explanation of your ring system for stabilizing these turnings. Can you recap it briefly for us?
Re: Plain Bowl 2
Me too & How big it that bowl?
Re: Plain Bowl 2
Re: Plain Bowl 2
Jason Nemec
Very nice. You are bringing just enough order to the chaos of that burl. The inner ring is nicely placed.
I've learned the hard way to think about the 3-foot placement carefully to make sure the piece stands up when you are done!
Re: Plain Bowl 2
Re: Plain Bowl 2
Barry L Elder
Just "plain" outstanding! Wow!!!
Re: Plain Bowl 2
Re: Plain Bowl 2
Ted Evans
Would some one donate a dictionary to Terry, apparently, he is confused by the meaning of "plain".
It is awesome, as usual.
Re: Plain Bowl 2
Leo Cuellar
Medicinal paraffin oil?
Leo Cuellar
Terry, your bowl looks great, wouldn't expect anything else :D You have mentioned sanding with oil before... is that the only type of oil you use, or are there other types that work? Do you then clean with mineral spirits after or some other solvent?
Thanks, Leo
Re: Plain Bowl 2
Re: Plain Bowl 2
Don at Central Illinois
My thoughts exactly. He doesn't know the meaning of plain. As usual, wonderful work.
Re: Plain Bowl 2
Re: Medicinal paraffin oil  replyby Terry  ?
Terry Scott
"Shell Ondina Oil 934
Medicinal white oil
Shell Ondina Oils are highly refined, non-stabilised, aromatic-free paraffinic or
naphthenic white mineral oils complying with the stringent pharmacopoeia purity
requirements. Ondina oils can be used in pharmaceutical, food packaging, cosmetic
and other applications, where this high purity is required by legislation or important
for the quality of the finished product."
This all started with a few memebers in our club that were getting acute reactions to some wood dusts
How I use it is by starting to sand with 120 150 grit to 240than with a spray bottle apply the oil for 320 400 grit
On harder woods like burl the oil only penetrates minimally,On softer wood it pays to sanding seal the timber first with 50 50 thinners to lock up the end grain and prevent the oil bleeding into the end grain causing a darkening of that area
The oil slurries up with the dust and for some reason sanding time is cut in half
A good call as heat checking is kept to minimum (yes I am to heavy handed
Sanding end grain lidded boxes inside with the oil is a dream .
After you finish sanding let the work sit a day or so ,cut back with oooo steel wool or 1200 grit wet and dry ,wipe sparingly with thinners then spray . Lacquers have natural drying agents that are spent once the product drys
If after a few days some end grain bled occurs cut back again and respay
I have deliberately kept back a couple of burls for more than a year to see if the finish has deteriorated and all is good
Some memebers of our club finish over the oil with a soft wax (I have started on craft items . With all craft bowls I know give a pot of wax free customers seem to like this as they are always asking what to clean the bowls with so they get a free wax pot and instructions to not leave in direct light ,wipe with a warm damp cloth then apply wax and buff (I also add dont wash in a dish washer )
See http://www.ecochi.co.nz/ a great wax Ive been using and have put my name two
also see application http://ecochi.co.nz/categories.php?category=Beeswax-Eco-Polishes/Finishing-Techniques-for-NZ-Native-Wood-
Please Note I endorse this product but have no financial gain or connection other than believing its great stuff .On my request another 15gms of Carnauba have been added to the formula This has added more of a shine to the finish yet was not enough to harden the wax
Re: Plain Bowl 2
Re: Ring system for Ellis
Terry Scott
Ellis Here is a picture of the support system
Sorry dont mean to be a smart arse but as we speak I am off to the post office to Post a disc that I have submitted an article on this procedure to a Wood turning Magazine
They have asked I keep it under wraps until publication
As they are paying I have to abide
Here is the first in the series of plain bowls
Re: Plain Bowl 2
Leo Cuellar
Great Info!
Leo Cuellar
Thank you, Terry. I'll have to give this a try, right after I deal with some mechanical issues. I have to get a new drive pulley, it is warped & giving me vibration. I just noticed that my tool rest is wobbling ever so slightly at the point where it enters the banjo... a couple thousands right over the post becomes a couple of mm out towards the end... aarrgh :\ Oh well, gives me an excuse to go to town.
