Electric Chainsaw
Electric Chainsaw
Electric Chainsaw
Dave Gelnett
I need to replace my electric chainsaw. In the past the electric chainsaws I have bought at the local hardware store that are in the $70 range last about a year. Since I normally only use this saw at my house to cut to length or split the log before taking to the bandsaw I would think it would last longer than a year. I don't even think I use it once a month.
Anyone have a electric chainsaw that is lasting longer than a year?
Thanks
Re: Electric Chainsaw
Bill Neddow
Yes,the Stihl electric chain saws will last decades, and they have as much power as a gas saw. Expensive, but well worth the investment. (This is from someone who bought a lot of cheap chain saws before taking the plunge and buying a Stihl. I have never been sorry.)
Stihl makes at least one model (Actually three I think) that are clearly in another universe from the $70 saws. I think Makita makes one and there is at least one other. It is my understanding that these saws sell for Something on the order of $400 to $650. The best of them are every bit as well made, durable, and powerful as many gas powered chainsaws.
This topic came up here about two weeks or a month ago and you should be able to find it with the search function.
Like you, I have trashed several of the cheapies. Simply can't afford a $500 electric saw. My solution was to go to (Dare I say it?) Sears and buy one that appeared to be made by Remington and put an extended warranty on it for an additional $12. They said that if it quit in the two years to bring it back and they would simple hand me a new one. Wouldn't you know it, it out lasted the warranty. But not by a lot. I rebuilt it and am still using it. It must be about 4 now.
I like the electric saw a lot. Always starts. Quiet. Clean(er). But, the boiler is crap. It just drools. So, I run mine without oil. Not aware of any problem from that. Maybe the chains die a little sooner, but how would I know?
Dave Gelnett
Thanks that is a good idea. Sounds like what happens when I buy my wife a camera. If I don't buy the warranty she will drop it within the first 6 months and it will never work the same. But if I buy the warranty it works well past the warranty.
I know it ain't so, but I am pretty sure it was the warranty that made it last over two years. Had I not bought it, I am certain it would have crapped out in about thirteen months. So the $12 was much cheaper than another saw.
Steven Antonucci
How to beat the warranty...
steven antonucci
Get yourself a piece of desert ironwood and reserve it for 725 days later...this gives you 5 days to kill it at the end of the two years. cut it through the growth rings as hard as you can. Should break any Craftsman product, and get you your new saw.
Best of all, your ironwood log will likely not suffer much damage and you can use it again in 725 days...
S
Boiler-does it run on Steam
I found an electric for $16. The oiler will run all of the oil out on the table just sitting there. However for $16 I wish I had bought 3 or 4. It doesn't have much power and probably won't last long but I figured at $16 it was worth a try. I hate waking the neighbors on Sunday morning with the chainsaw. They all sleep till about 10 on Saturdays and Sundays and I'm up at about 5 or 6 and ready to work. I've watched these threads closely and will probably go the Sear route when I decide to buy a more powerful one. This saw won't get a lot of use because I have the bigger Husky's when I can make noise.
Barry L Elder
I have an old Craftsman electric chainsaw that I bought during a pre-Christmas sale about 4 years ago. Had to replace the chain as I wore out the first one. Still running as good as new even though it gets verrrrrry grimy!!
D. Hansen
Remington and others that have a plastic drive will not last long if you cut relatively hefty logs. Makita makes one that is clean and sturdy. Runs a bit more $ but does work well. It is a bit slower than gas but much quieter. The oil it uses is regular 30 wt not the more expensive bar chain oil.If I remember correctly the Remington, Craftsman, and other similar ones using the plastic gears are made by Electrolux Vacuum Cleaner people.
Ed Wujciak
I have a 16" Makita that I found new on the internet for under $200. Wonderful machine.
robo hippy
I bought a Husky some years back, and found out after burning up two motors that you can not push this type of saw at all. You have to let the weight of the saw determine how fast it cuts. Any more pressure and it burns up.
Since I got my Laguna 16HD bandsaw, I almost never use the electric chain saw any more.
robo hippy
gtwilkins
I don't know anything about this company but I found the price not too heavy.
Does any one know this saw?
www.magnumpowersalesdot/chainsaws.html
(replace the dot)
Trevor
Walt Bennett
Stihl is the only way to go (NM)
Walt Bennett
Charles Watson
Bought a Makita years ago--one of the best purchases I have ever made.
Terry Scott
No sorry I like the noise of a gas saw
Seriously I dont own a electric saw as I find I can do most things on my big band saw
When I am out cutting timber I always make sure I can lift the things I cut this means I can get it on the band saw
At work I use an electric Makita seems to work ok as long as they dont give it to me to use it
