New captured parting tool
Hopefully in the next few days I will have time to try out my new parting tool. It is a metal cutting tool mounted in a 1/2"x1" piece of flat steel. The other end has been turned down to 3/4" to fit my captured boring bar. I'm hoping this will let me use the captured bar to cut the rings for the bowl from board projects. I think by placing a clamp as a sort of guide on the secondary tool rest I can set a precise angle and be able to cut it accurately and with much less burning and cussing. We'll see.
Re: New captured parting tool
Galen Vetterick
Looks like you went carbide and not just HSS on your cutter.
For a guy who says he still has a day job you sure get a lot done "playing" with new ideas in the shop. :-)
Great to follow your progress on each of your ideas.
No it's HSS. The reason I picked that one is that it is wider at the top than the bottom so it should not heat up at all. Normally that would be an invitation to a catch when it tries to twist. Since it's captured in the captured bar then this won't be a problem.
Keith Tompkins
Keith Tompkins
That's very slick, John. Nice!
Matt Overton
I like it alot, John. what is the thickness? The photo makes it look pretty thick.
Matt I think it's an 1/8" but I'll have to go measure. I bought 3 different sizes of cutters to see what they are. It might be 3/32. I'll measure it tonight. I might have time to use it this evening if my afternoon shoot doesn't run long.
Galen Vetterick
John
I had just purchased this cutter at Harbor Frieght to make a small parting tool when working on smaller turnings. Looks similar to yours. This does not have the wider top that I thought looked like carbide in your picture.
Now when I say smaller parts that's nothing like your micro goblets!
Will be working on a handle for it today.
Looking forward to your posting of your cutter in action.
