Micro mini goblets.
Micro mini goblets.
Micro mini goblets.
Well I spent some time setting up a better rig to hold my stereo microscope and then turned some micro mini goblets. I used my cross feed vise to be able to position the miroscope. I took the rail off my camera bellows unit and attached it to the microscope for vertical adjustment. I still didn't have a good way to tilt it for hollowing the goblet but I got by.
Here is a close up of the tool rest and chuck along with my "roughing tools" that are .025" piano wire, and then my finishing tools that are .015" piano wire. The small ones took some getting used to because any pressure at all on the tool rest caused them to flex and change the cut. The ones with 7 lines are skews and the ones with 5 lines are the gouges. I used mostly the skews. It's amazing to watch it cut just like they do when they are large. You can roll the skew over when doing the bottom of the goblet bowl just like you do with a big skew only you better do it really really gently.
Here is a so so shot of the goblets. I don't have the proper lenses to do a good job of shooting them here at the house. The biggest is .100 or just under 1/8". The smallest is .040" and about .017 wide or about as tall as a penny is laying down. Idon't know what wood the big one is but the smallest ones are Tulip wood. The smallest is a little bigger than my previous small one but the shape is much more like a real goblet.
Re: Micro mini goblets.
Bill Turpin in WNC mountains
John: this is meant as a complement. YOU ARE CRAZY! Have you ever lost one of those under your fingernail?
Steven Antonucci
borrow some tools
steven antonucci
cause I thing you'd got a screw loose! :b
That is so incredibly nuts, I can't even imagine trying it. Can you even breath while you cut, or do you have to just cut in between heartbeats. cutting .001 per pass must be the ultimate in tool control!
Kudos to you.
Steven
Bill last time I lost several. I improved my capture method for catching them when I cut them off. This time I didn't lose any. I think I've about reached the limit on diameter since I blew up the goblet bowl on 2 and the foot on one. I'm going to find a way to measure it accurately next week. I think the stem is on the order of .010" but I don't know for sure. I have a friend in the lab that has the electron microscope and other high quality measuring devices. He says he thinks he can measure it for me. Don't know when I'll have time to get over there I've got a busy week coming up.
Re: borrow some tools
Steve The fun part was sharpening the tools. I used the ultrafine diamond hone. Through the microscope it looks like I'm sharpening on the sidewalk. After that I went to the green leather strop and got rid of the tiny wire edge. I was pretty shaky on the first couple but after a little practice I got to where I could remove the tiniest slice you can imagine. Believe it or not you can actually feel when you are getting a clean cut.
I can't praise the powermatic enough. No vibration and I could move the big cast iron tool rest a few thousandths to get the small tool rest closer. Raising and lowering the tool rest was tricky. I'll have to work on that one.
Lyle Jamieson
Lyle Jamieson
Look at my threaded post tool rest forgetting the nub in the bottom of hollow forms. My photo file was too big to post here so go to me web site if you want a photo. The nut gives you infinitessimal adjustability. I thought that kind of thing was in the photo of your mini tool rest.
Leo Cuellar
Incredable!
Leo Cuellar
Wow, John, that is just truly amazing. What other kinds of wood have you tried? Would something like pear or box hold together better? I've got a chunk of box that you could probably make drinking ware for an entire ant colony from :D
Great work on the tools, very smart to code the handles as well. What I would try with the tool rest is making another with a longer threaded portion then bore out the mounting plate so the threads no longer engage. If the wings wouldn't get in the way, you'd be able to adjust it up & down fairly easy with a wingnut top & bottom of your mounting plate.
I have a threaded rod tool rest platten that I use for the router. I thought about making one for this project but I was half way through what I planned to do so I just put it off to another day.
It would be better if it was keyed so it would only move up and down when you loosen that part. the swivel could be a second adjustment. I think I can do that by making a 1" sleeve for the bottom of the tool rest. Put a pin in that and then cut a groove in the threaded rod that will fit inside it. Then I would have both. I would have to put a separate locking lever on the threaded rod portion of the sleeve.
Re: Incredable!
Leo Some woods won't work. Holly for example is too flexible. Some Ebony has microscopic pores that can barely be seen at 20X mag. If one of those is in the stem or goblet bowl they blow up. I haven't tried Boxwood but suspect it would work because I've chased threads in it and it looks very clean. I've had good luck with Yellow heart and cherry.
Galen Vetterick
Sure gives a whole new meaning to having a sip of wine at the Lucas home!
It sure will make a bottle of wine go a long way for your many friends.
Guess you now need a serving tray and wine bottle to round out the setting.
Fantastic goblets!
Rob Wallace
Other woods???
Rob Wallace
John - Have you tried African Blackwood or cocobolo? Osage orange? Pink Ivory? - all of these are finely grained woods that take detail pretty well....some are pretty hard, but could be cut OK with sharp tools. I think that Af. blackwood would also produce excellent goblets, but you'd need to accentuate the lighting/contrast to be able to see what you're doing on such a dark wood. I think you could probably put a bead on the stem of one of these if you tried it with blackwood - fantastic stuff..
Rob
Wayne Kuhn
So when are we going to see some captured rings on these goblets?
Really amazing stuff.
BTW, I have some 1/8"x1/8" scraps I've been holding onto for some unknown reason. Your welcome to them.
Wayne Kuhn
Columbia,MD
Charles Yawn
John, I sent your penny image to some of my non-woodworking friends. One responded asking where you got such little trees to work with. I'm pretty sure she was joking. Charles
Lyle Jamieson
Lyle Jamieson
Yes, you got it. Threaded rod for a post, the nut gives the adjustability, and the locking handle holds it in position in the banjo.
I cut up bonsai trees for the wood:)
Doc Green
What I'm wondering is where he gets those BIG pennies.
What, no captive rings???
Jorge Casta�eda
Finally had time to try and get a decent photo of the mini goblet. Here it is. I still don't like the shape but the stem is something on the order of .010" and I really don't think I can make it thinner. So I have to decide if making a better shape is more important than making it as small as I can.
